Reversing Start & Kill switches - 2018
I came off a Beta which had Kill LHS & Start RHS. I have an '18 EC250 Six Days & I was laughing in my helmet the other week when I stopped on a hill & was pressing the Kill trying to restart the bike.
It is weird for me so I decided to swap the switches around. I re-wired the stock Kill to be a Start & canned the bulky (& ridiculously expensive to replace) Leonelli switch block in favour of a waterproof $5 On/Off. There is no room for the stock Leonelli Start block next to the throttle due to my preferred front brake perch position, anyhow. It took 45 minutes & cost $5. Hint - I filled the Leonelli male side of the big black connector with Liquid Electrical Tape after I'd wired in the Start switch & turned it pins down behind the headlight shroud to lessen water/dust ingress. The horn's gone (I blip the throttle to get attention anyway) & the headlight is hard wired for low beam. I don't ride on the road here (or at night), so all good! Had a test in the bush yesterday & all worked fine. Last edited by Gibnut; 05-08-2018 at 10:56 PM. |
I flutter my eyelids.
Doesn't seem to work though
Do you shake your fanny pack?
You read my mind! That was one of the first things on my to do list when I get a new gasser. That layout is just weird!
Good call ....my start button is intermittent now on my 2018 ec ill give this a try
We pulled the loom apart slightly on a mates 15 and used a KTM setup I believe.
I'm an outlier, I like the starter on the left in case I need to blip the throttle when starting, it's easier for me if the starter button is on the left.
I did the same, but used the xc switch.
http://www.gasgasrider.org/forum/showthread.php?t=23516
EC300 2019 (11 Gassers owned, many more to go) |
2018 YZ450 Electric Start Only-$9199.00 | Moto7man | All Other Bikes... | 4 | 06-16-2017 05:53 AM |
Three Year Head Start -- Parting out in 2018 | AZRickD | Parts | 2 | 07-10-2015 09:49 AM |
Alternative starter / light switches? | SingleTrackMind | Enduro Electrical & Wiring | 3 | 05-07-2014 05:19 PM |
Brake light switches | Wilksiee | Enduro Electrical & Wiring | 5 | 03-07-2012 10:59 AM |
Changing Electric start to two kill buttons | Woodsknight | Enduro Electrical & Wiring | 4 | 03-19-2011 10:28 AM |
