Old 12-05-2016, 11:44 AM
Jimmy Jimmy is offline
Unhappy Issue with ac-dc converting.. Please help pic inside
Is this the right way to do it?
Would love some help.
Old 12-05-2016, 03:00 PM
Brian's Avatar
Brian Brian is offline
You can't have both AC and DC side grounded to the frame.
One or the other should not be grounded to the frame, "floated".
I think I am floating DC. So every ground needs to be run back to the battery negative terminal.
EDIT: Actually, I took a closer look and it does look this is what you have drawn. Sorry!
2006 Gas Gas EC250
2011 Husaberg FE390
Old 12-05-2016, 05:02 PM
thumperflipper thumperflipper is offline
this video series is from my conversion on an 07, not sure how the 12 is wired though. Here is part one:
https://www.youtube.com/watch?v=0WHL3QqLLxE
07 GG EC300
11 GG EC300E
Old 12-05-2016, 05:47 PM
Neil E. Neil E. is offline
Your diagram looks fine to me.
2011 EC250E
Old 12-05-2016, 10:43 PM
gasgasman's Avatar
The wiring schematics are in the manuals here.
http://www.gasgas.com/us/manuals/1.html
Old 12-06-2016, 04:00 AM
My issue is that when im running my bike without using my led, its charging around 16-17v!?
But as soon as i turn it on, the V is dropping fast from the battery.
Skickat från min iPhone med Tapatalk
Old 12-06-2016, 04:13 AM
So i have to open up my stator och do the floating ground thing you talked about?
Old 12-06-2016, 11:17 AM
There is no value to floating the stator on a standard kickstart bike.
A grounded stator and an isolated rectifier will do what you need. You feed the rectifier with the white wire and ground. The DC output connects only to the battery and your lights.
If the voltage seems a bit high, try using the yellow wire to power your rectifier (leave the white wire disconnected). You should confirm the actual current draw of your LED light. Use an amp meter and a car battery to find out the draw. Assume 2K3 at 70W/14V=5amps at high RPM, so stay below 4amps on your lighting.
A voltage drop under load is normal. As long as you can maintain 13VDC at the battery (under load) you should be OK.
2011 EC250E
Old 12-06-2016, 12:57 PM
Default Issue with ac-dc converting.. Please help pic inside
Yea, but a 40w led should not be more then 5amp right? Might be that the lamp is pullibg to much then cause my volt is dropping fast on the battery even on pretty high rpm. I need a new light i assume then... my battery dropping fast dom to 8-9v
When you say feed the r/r with white cabel and ground.. should i take that ground from frame or the - on the battery?
Old 12-06-2016, 07:32 PM
Input to the voltage rectifier is stator white plus frame/chassis ground (or can be stator yellow plus frame/chassis ground at slightly less voltage). Do not ground the battery minus!
If you get a lot of voltage drop, either your lights draw too much current OR you have a bad connection somewhere. A bad connection will reduce current flow but still can measure OK for voltage. A really bad connection will drop voltage. Bad connections can be wires OR ground points. You need to go through everything carefully, even the quality of your switch contacts is important.
Have you checked to make sure the stator connections are not corroded?
2011 EC250E
Converting a 250 to a 300 Niall-griffiths Enduro Engine - 2 stroke 14 11-16-2014 05:23 PM
Converting a EC200 to a EC300 Ply318ci Enduro Engine - 2 stroke 19 12-12-2011 08:28 AM
Converting a Sachs shock to fit a bladder? Keg Enduro Suspension 12 06-22-2009 11:17 AM
Converting 2009 EC300 to Motard cheekeon Enduro Chassis & Body 0 04-12-2009 03:04 AM
