Old 08-15-2017, 06:28 AM
hamilton's Avatar
hamilton hamilton is offline
Originally Posted by periclesgsilva View Post
U mean Lever failing when u need to use a clutch big time? No clutch on Lever?
Enviado de meu SM-G935F usando Tapatalk
Yes, the master cylinder seals were ruined from piston debris not being cleaned after machining.
15 GASGAS EC 250
19 Sherco SE 125R
Old 08-20-2017, 05:35 AM
SpirosZ1000's Avatar
SpirosZ1000 SpirosZ1000 is offline
Same here. My 2015 clutch lasted for half a ride and then started losing pressure.My dealer replaced it with a brand new which I still have in the box as I had a clake one finger from my old gasser which I used.
Στλθηκε απ το Neffos X1 Max μου χρησιμοποιντας Tapatalk
Gas Gas EC 300 2006
Gas Gas EC 300 R 2015
Gas Gas EC 250 GP 2018
Old 08-20-2017, 05:35 PM
ljdb ljdb is offline
my 15 played up as well in short time. Iv bleed and changed the clutch fluid but haven't really given it a work out since. ATM gasgas Australia has 50% of parts as they are changing distributor. Ive ordered a magura master off another model as its dirt cheap, a seal kit for my 15 and a heap of other bits.
Old 08-21-2017, 09:10 PM
compmoto's Avatar
compmoto compmoto is offline
Default clarification please
are you meaning from new ? as in from the factory ? I've had a 125 that I've rode approx. 45 mins with no issues, then another 15-20 mins and piece of what appeared to be "welding slag" was found in the slave piston area, seal was toast, and it beat on that end of the slave cylinder...enough to warrant replacement... I am trying to understand how anything could be in there from the factory ! I've never heard of it before on a new bike anywhere...
XC300,RM250,X440,EC125
https://www.facebook.com/groups/gasgasoffroadriders/
Old 08-22-2017, 11:20 AM
hamilton's Avatar
Originally Posted by compmoto View Post
are you meaning from new ? as in from the factory ? I've had a 125 that I've rode approx. 45 mins with no issues, then another 15-20 mins and piece of what appeared to be "welding slag" was found in the slave piston area, seal was toast, and it beat on that end of the master cylinder...enough to warrant replacement... I am trying to understand how anything could be in there from the factory ! I've never heard of it before on a new bike anywhere...
Yes, from factory, straight off showroom floor. It was just poor quality control from AJP. I know of 4 that had the same problem and 2 that didn't in my area (14/15's). Replacement with a Magura master cylinder is the easy cure, has a much better feel also.
You say your slave piston seal(on engine) was damaged? I don't follow how that had any effect on the master cylinder???
15 GASGAS EC 250
19 Sherco SE 125R
Old 08-22-2017, 08:50 PM
compmoto's Avatar
Default cornfused
sorry, maybe I have confused the thread as "clutch" in general...my problem is at the slave end...
I've had to order 2 pistons @ $50.ea , and today I ordered a slave cyl. assy. from Matto. God knows what that will cost
if ya need it, ya need it...
Old 10-16-2017, 05:08 PM
Neil E. Neil E. is offline
Originally Posted by arminhammer View Post
I took a die grinder and cleaned up between every pad on the fiber discs on my wifes 11 250. The clutch is now better than anything I have ever used. It takes some time but did wonders.
I tried this on my clutch and noticed some improvement. I was only going to check the frictions for wear, but when I noticed the plates were getting thin, I decided to try Armin's modification. The frictions were worn down to the point where the standard grooves were barely visible. They have almost 7 seasons of use.
I'd guess that deeper grooving allows the frictions to sweep more oil from the steels and reduces squawking. The improvement I noticed might be from the fact that the plates have grooves once again.
It is a time consuming job considering that there are 36 grooves x 2 sides x 8 frictions = 576 grooves. Maybe I should use them for another season to justify the work.
If I get new plates, I better get a spark plug too (just to keep Mr. F5 happy).
2011 EC250E
Old 10-16-2017, 11:39 PM
I think I did about 2 grooves and decided it was easier to get earplugs so I couldn't hear the squealing
2003 txt250 Pro
2013 Ossa 280i
Clutch master issue Bulgas Enduro Engine - 2 stroke 13 01-29-2014 10:53 AM
clutch issue gasn4christ Enduro Engine - 2 stroke 4 10-13-2013 03:02 PM
2003 ec250 clutch issue dirt2road Enduro Engine - 2 stroke 12 08-17-2012 03:15 PM
Clutch Drag Is Not An Issue! Rick Pictures & Videos 7 11-25-2010 07:50 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
