Old 10-04-2017, 07:06 PM
gasgasman's Avatar
The counter balanced engine did end in '98.
The Ducati stator's magnetic field also acted like a flywheel.
Old 10-04-2017, 07:08 PM
gasgasman's Avatar
Originally Posted by 70455gto View Post
The top piece is a flywheel.
The bottom piece is a counter balancer.
Old 10-04-2017, 07:35 PM
70455gto 70455gto is offline
Do I i install flywheel or counterbalance to the cranK behind gear that engages clutch basket?
Old 10-05-2017, 09:39 AM
slocalspode's Avatar
slocalspode slocalspode is offline
Here is the clutch side.
Not sure which gear / weight you are looking for.
If you look close, the gear that drives the counter weight is aligned
incorrectly. There are punch marks on the two gears that are supposed to
be aligned.
Hope this helps.
Old 10-05-2017, 01:00 PM
Zman's Avatar
Zman Zman is offline
I suppose any electrically loaded lighting coil will eat up HP and oppose engine RPM increase like a FWW, but the magnetic field will not help with stall prevention like a rotating mass.
Old 10-07-2017, 10:31 AM
Installed new 6306 c3 crank bearings and relative motion between crank journal and inner bearing race (slip) requires much more force to impart.
2001 crank had a much much tighter fit with crank bearing id.
Cannot find info on how to make crank larger.
May look across to other 2t models for similar issues.
Tags
bearing, crank, radial, spins
Crank bearing failure .WTF ? Getoviq95 Enduro Engine - 2 stroke 2 04-16-2017 01:27 AM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Crank bearing help please!!!!!!! Porkyblader Enduro Engine - 2 stroke 2 09-09-2011 04:46 PM
07 Crank bearing... NEED URGENT HELP. wence Enduro Engine - 2 stroke 11 05-23-2010 02:25 PM
2007 EC250 Crank Bearing? BIG TOOL Enduro Engine - 2 stroke 9 11-23-2007 02:47 AM
