Metal piece
Hi I own a gas gas ec 200 2006,just done a gear oil change and pulled a piece of metal out of the drain hole,the bike has been running fine and gears seem to work nice,the piece has ABEC-1 on it,anyone have any idea what it is and where it came from ?
Looks like part of a ball bearing .
The ball bearings at the outer ends of the transmission gear shafts have a metal shield, that would look like this. |
Go to "Exploded view".
Scroll down to the transmission section. https://gasgas.com/en/manuals?c=&y=2006 |
looks like a metal bearing seal (if the metal oneas are called seals) and i think abec is a brand of bearing. Cant help with where it has come from, but the question should be ... where is the rest of it?!
Yikes! I agree, it's part of a bearing. I would be splitting the cases immediately to fix it before it becomes worse.
+4. If that locks up bad things will happen. Hopefully you've caught it in time. The good news is the come apart easily without a splitter.
Anyone had a 2 piece gas tank apart? | GGRider01 | Enduro Chassis & Body | 2 | 11-24-2016 04:15 PM |
museum piece 1998 EC250 needs bottom end | savage sausage | Enduro Engine - 2 stroke | 2 | 08-20-2015 06:07 PM |
Metal on metal sound when O-rings from exhaust wear out. | Scar13 | Enduro Engine - 2 stroke | 11 | 02-02-2013 08:19 PM |
Large piece of metal from drain hole??? | desertgasser300 | Enduro Engine - 2 stroke | 16 | 06-22-2011 08:12 PM |
3 piece sprocket | geraldh | Enduro Chassis & Body | 5 | 10-05-2009 07:10 AM |
