Hi all, I write from central Europe, from Czech Republic-we have here very very dangerous problem with brand new Gas Gases model year 2008. The problem is in the pipes and front wheel-when you push front wheel about 220mm of its suspension, it begins to collide with exhaust pipes-as you can see on the pictures:
suspended 220mm: front wheel begins to collide with pipes:
suspended at maximum: the wheel must be slightly turned, because pipes blockade the wheel. (That´s why it is so dangerous-you land after some jump and it is same felling as you fully breaks with front brake
Total hazard!
Same situation but from the other side-you can see that front wheel collide with pipes at about 4cm! (about 2 inches):
The bike is comletely new, and it isn´t only my friend´s problem, I heard about same thing from many many people around central Europe. If you want to complain about this problem to our local dealer he says that you are lier, everything is ok and no one has same problem - only you.
What the #### is doing Gas Gas from us? Fools?
