EC250 1998 workshop manual
Does any one have a workshop manual for a EC250 1998????
I found a 2003 manual on line but its too new.. thanks darren |
Very few if any major changes beside the newer manual is all you will find.
Main reason for askin is in the 03 manual the left hand cover revealing the rotor looks different to mine. and what looks like a counter balance shaft. which is not in the manual. I was curious as to how to remove the rotor. In the manual the rotor covers the coils but on my 98 the coils are housed in the casing and the rotor is bolted onto the crank. I was wondering if there is a special tool for removing the rotor.
The '98 has a lighting coil on the outside of the flywheel in the housing(it's a ducati lighting coil), The piece That goes inside of the coil will unscrew from the flywheel,(lefthanded threads), then you use a flywheel puller on the flywheel, it's the same puller as most jap bikes, suzuki for sure, in fact the ignition stator is the same as '91 -'95 RM, I've taken them out of an RM and bolted them right in the gasser without any mods, and the same flywheel as the RM 250 from the same'91-'95
99 EC 300 |
Here are links to the 1999 manuals (in english). I'm assuming the 1998/1999 will be the same. This is the only source I found for these. The quality of the early parts manuals is marginal, but it is better than nothing.
http://212.166.128.102/GASGAS/1999/ec1999_engine.pdf http://212.166.128.102/GASGAS/1999/e...rame_print.pdf Here is the website in case the links above do not work (note: it is a spanish website). http://www.embarrados.com/gasgas/viewtopic.php?t=958
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
Bumping this so I can find on my laptop and try links later
workshop manual | 2stroker | Enduro Engine - 2 stroke | 3 | 10-30-2008 10:21 AM |
workshop manual | 2stroker | Other GasGas Bikes/Quads | 0 | 10-27-2008 07:15 PM |
Workshop Manual GG FSE450 '04 & '05 | timw | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 08-01-2008 12:52 AM |
Workshop manual | rupecopp | Enduro Engine - 2 stroke | 1 | 10-04-2007 03:59 PM |
Where to post workshop manual PDF's? | Radbuster | General Discussions & Announcements | 8 | 07-16-2007 01:51 PM |
