2001 ec300 power valve free play
Hi,
Per the video the actuator stays open if i slowly move the plate, but if i move it sharply and let go it does snap shut. Is that normal behaviour? Would i use the right screw near my finger to adjust the arm up further? I also want it to open sooner in general, so which of the shims should i remove, closest to engine or furthest? I am assuming the bushing things on either side of the pin are the shims. https://youtu.be/4QrYbH3m6Bo
2001 EC300, mild porting and head work, DEP silencer, EC200 CDI |
I believe I used the allen key pointing towards the camera to adjust mine. Needs to be shut firmly otherwise the valve will flutter.
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
'14 EC300 Power valve not opening | poelinca | Enduro Engine - 2 stroke | 9 | 09-17-2015 02:58 PM |
Throttle free play | 95jersey | Enduro Chassis & Body | 6 | 06-25-2015 05:07 PM |
Slight free play in forks | 400_racer | Enduro Suspension | 9 | 06-27-2012 09:38 AM |
Free Play in Sachs Forks? | 2whlrcr | Enduro Suspension | 10 | 03-07-2011 10:45 PM |
2011 ec 300 Throttle Cable doesn't have any free play... | rgranger | General Discussions & Announcements | 7 | 01-29-2011 10:03 PM |
