Old 02-08-2019, 06:05 PM
sammittrue sammittrue is offline
Default 05 300 EC stator compatibility?s
Hi my sons 05 300 EC started developing stater issues, gas gas was asking $340 for a brand new unit. Ricky stater offered $250 for rewind. my question is they look very similar to 00-07 ktm 300 stators. Are they compatible? I believe it?s a 2k2 stator. Any and all input appreciated. Thanks
File Type: jpg 2EE2D91A-418D-4121-83F0-193C8DAD4B0F.jpg (118.2 KB, 20 views)
Old 02-09-2019, 08:30 AM
I believe you will need to mount the stator on the GG backing plate to get the orientation/timing correct. Do the two stators look the same (coil orientation relative to the mounting holes) and do they have the same wiring? If they look very similar try it and see. If they are not very similar in orientation / clocking with same wiring you will have more work to do.
Old 02-09-2019, 09:45 AM
To be honest I?m not sure if what I took off the bike is the OEM stator. It?s completely different from picture in the manual. As far as comparing my stator to the ktm (witch I think is what this is) the pick up is slightly clocked different between the two. What a mess. Heres a photo of mine vs what I?m hoping will work after changing the wire connectors. What do you think?
File Type: jpg E57DA272-FCD9-4BDD-8106-FF41441C7671.jpg (118.2 KB, 15 views)
Old 02-09-2019, 09:47 AM
Not sure why it didn?t upload but hers the new unit
File Type: jpg F73CDD43-D9B4-40C3-9DF5-19AC68CD0258.jpg (7.1 KB, 16 views)
Old 02-09-2019, 11:29 AM
That photo is really small. Can you post it larger? Can you also post the ktm and GG stator plates side by side?
Old 02-09-2019, 11:33 AM
Neil E. Neil E. is offline
Look at this topic:
http://www.gasgasrider.org/forum/showthread.php?t=23712
It shows the GG/KTM comparison for the larger 2K3.
You should be able to do the same thing with the 2K2.
Old 02-09-2019, 11:54 AM
I got my ktm stator from Electrix for my ec300 07.
Old 02-10-2019, 08:07 PM
SS109 SS109 is offline
Learn to roll your own. I've rewound stators myself with good results. It just takes patience.
Old 02-11-2019, 01:45 AM
Hi voltage coils encased in resin on plastic forma. Swine to separate one from the other. Can't burn it off without destroying it.
Old 02-11-2019, 03:07 PM
Correct. It can be somewhat frustrating but worth it IMO. You gotta do either the source coil, which is only one pole, or the lighting coil, which is the rest of the poles, or do both circuits completely. It isn't that hard to do. It just takes patience and a steady hand. Like I said, I've done it and I'm just an average guy with no special tools or training.
Rear sprocket compatibility Bentiggerwyles Enduro Chassis & Body 3 08-10-2017 05:48 PM
Clarke Tank Compatibility 2010 to 2011 gasgasfk General Discussions & Announcements 5 08-25-2012 08:34 AM
2011 Clark Tank compatibility gasgasfk Enduro Chassis & Body 1 08-23-2012 05:47 PM
frame compatibility? dirtrider0129 Enduro Chassis & Body 1 02-06-2011 07:14 AM
2010 EC250 4T Aftermarket Exhaust Compatibility Jeffro General Discussions & Announcements 3 10-27-2009 04:45 AM
