Old 01-16-2017, 05:05 PM
tbt420 tbt420 is offline
Default Ec 300 Power Valve Binding
So during a full rebuild of my 1999 Ec 300 I cleaned the entire power valve so it shines I put I t all together today and I am getting some binding in its rotation. I was wondering if the grease and grime that was in it was somehow keeping it lubed or if there is something else to look for. It seems to be binding on the side with the arm on it. Thanks in advance
Old 01-17-2017, 03:47 AM
VilluEST VilluEST is offline
Is the actuating rod (the one that comes from crankcase) free in it's entire range or maybe it's binding to the cases? Also, the PV housing in cylinder is most likely full of grime, if you cleaned only the flapper valve and it's mechanism.
Old 01-18-2017, 07:35 AM
SwampGasser SwampGasser is offline
Make sure you installed the washer on the upper end of the actuator rod. If not installed, nut could be tightened to much causing bind between rod and cam piece.
Old 01-19-2017, 12:04 PM
I use unsealed bearings for that, and put them in clean
2016 RM-Z450
Tags
gas gas, power valve, top end
Ec 300 power valve Jonisaacson17 Enduro Engine - 2 stroke 11 07-18-2016 09:01 PM
Power Valve ? BigAl Enduro Engine - 2 stroke 4 01-05-2015 09:08 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
