Old 05-22-2019, 08:59 AM
northernhammer northernhammer is offline
Default 2011 300 gear shifter
I bent my gear shifter last night. Has anyone had success bending these back? I was going to put some heat to it & give it a whack on the anvil but I'm not sure that's the best way to go about it. If it does break does anyone know if a shifter from another brand will fit that I can source easily? Located in Canada.
Thanks!
Old 05-22-2019, 11:44 AM
I would not try and strike the shift lever as aluminum is not very ductile and a sharp blow may crack or break the lever. I would apply heat and use a vice and a short cheater bar or pipe wrench to gently bend the lever. Try and bend in couple/few different areas, so as not to fatigue the metal in one spot. Dont get it too hot, aluminum has a low melting point and you do not want to anneal the metal either.
Old 05-22-2019, 11:47 AM
https://www.ebay.com/itm/EMGO-STEEL-...frcectupt=true
These Emgo shift levers are cheap and readily available. It is the stock lever on the '18+ bikes, I believe.
Old 05-23-2019, 01:32 PM
Thanks for the info Jacob. I applied heat with it in the vice & slowly applied pressure, let off, pressure again till it was back to normal. Went out for a ride & all was good
I also ordered on of those replacements you linked just incase. Might be a little weaker than before.
2011 300- broken first gear Bark3rd Enduro Engine - 2 stroke 6 03-08-2015 12:08 AM
Ec 1997 gear shifter EC250 Enduro Chassis & Body 4 07-21-2014 08:48 PM
EC 125 Gear Shifter Problem jonnyweston Enduro Engine - 2 stroke 6 09-17-2007 11:41 AM
