Small amount of oil in crankcase
I just picked up a brand new to me 05 ec300. I have receipts showing that it had a complete rebuild in May of last year. New bearings, seals, rod, piston and so on. It has had the head done, Lt power valve cover, and so on. I did my first oil change the other day and pulled the crankcase drain plug by mistake and I got a very small amount of oil out of it. Maybe 5 or 6 drops. Anyone else ever have this happen? My first thought is crank seals but it runs way to good to be burning gear oil AMD the gear oil didn't smell like gas. Help?
Oil in the crankcase is a good thing.
15 GASGAS EC 250 19 Sherco SE 125R |
2 strokes tend to like it.
Some even call it lubrication.
All healed up, and ready to burn some fat. |
Hmm. I guess so but I have never seen oil standing in the crankcase of a 2t. But then again I have never had one with a drain plug in the crankcase
Oil will always be present in the crankcase. Oil vapor coats the surfaces as it passes through the engine. Some condenses and sits at the bottom. It never amounts to much quantity as the crank will pick it up and sling it back into mist.
2011 EC250E |
Thanks Neil that's what I was asking
Keeps the main bearings rolling smooth!
Memphis2857, I think you and Neil (and everyone above) are right about your assessment... last year I had black transmission oil at every oil change, losing trans oil (put 900 in, got 700 out when drained at oil change time), exhaust spooge all over, and running rich. And yes vacuum from piston going up was pulling trans oil into the crankcase, and I would drain a small amt of trans oil out at each oil change, maybe a few cc's. These are symptoms of leaking R side crank seal (and maybe main case seal?). Changed the right hand crank seal and viola, trans oil clean now, no volume loss at oil changes, and nasty spooging gone, running much cleaner since then...
07 GG EC300 11 GG EC300E |
WEC Line-up: Good amount of Gassers! | firffighter | General Discussions & Announcements | 3 | 03-17-2012 12:33 PM |
Coolant in crankcase = no fun | stainlesscycle | Enduro Engine - 2 stroke | 35 | 02-02-2012 09:59 AM |
Crankcase Seal Removal | gasser | Enduro Engine - 2 stroke | 4 | 10-06-2009 12:47 PM |
Crankcase vent blocked | kendunn | Enduro Engine - 2 stroke | 2 | 10-06-2009 12:37 PM |
Crankcase steam hose | Alan | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 07-06-2007 10:15 PM |
