Old 08-27-2019, 02:07 PM
ssaulnier's Avatar
ssaulnier ssaulnier is offline
Default Rear Brake Pedal Height Adjustment
How can I lower the rear brake pedal on my 2018 EC300?
It is presently a little too high for comfort.
Old 08-27-2019, 03:17 PM
Adjust the pedal height at the master cylinder push rod.
Old 08-28-2019, 11:22 AM
ssaulnier's Avatar
Roger that, will give that a try. Thanks for responding! Steve
Old 09-01-2019, 08:36 PM
shawbagga's Avatar
That's only for freeplay isn't it? Same as front brake. No adjusment unlike Brembo.
'18 Gasgas XC250
Old 09-01-2019, 08:59 PM
No. That's the height adjuster also.
Old 09-03-2019, 01:04 PM
ssaulnier's Avatar
I was able to successfully lower my brake pedal height by loosening the lock nut near the bottom of the master cylinder plunger threaded rod and then turning the plunger where it emerges from the master cylinder rubber boot.
Easy and worked a treat!
Thanks for posting gasgasman!
Cheers Steve
Old 09-04-2019, 04:36 AM
Pygmygod Pygmygod is offline
Get yourself a manual, explains it and with pictures in there for you.
Steering lock/Brake pedal height adjustment fletchman45 Enduro Chassis & Body 14 06-04-2013 11:52 AM
Lowering Rear Brake Pedal Height? 2whlrcr Enduro Chassis & Body 9 08-29-2010 06:17 PM
Rear brake adjustment Silver Enduro Chassis & Body 5 06-03-2009 07:50 AM
Rear brake pedal HydroDog Enduro Chassis & Body 0 03-09-2008 10:48 PM
