Old 12-30-2006, 03:32 PM
PEB PEB is offline
I use the screw driver method. Before my backpack with a sweet selection of tools got stolen I used a chain press. Regarding installation of the masterlink, I recently saw pictures of the cases on a WR that had a masterlink failure and they were ugly. A simple way to prevent such a catastrophe is to install the master link such that the clip is on the inside of the cahin. If it fails, it would come out away from the cases not grind/cut into them.
Paul B
02 se 300
02 WRX
Old 01-27-2007, 06:50 AM
Hawkeye Hawkeye is offline
PEB, that is a great tip, thanks.
Matt, call me a caveman, but I've been gently prying my links off with a screwdriver since 1982. Never a problem. Maybe I'm one of those intelligent, sensitive cavemen like the ones in the Geico commercials...
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
Old 01-28-2007, 12:15 PM
tprnottp tprnottp is offline
MattR:
I too use a "removable" master link for my D.I.D x-ring chain. To remove it, I use a small two-jaw gear puller, placing the "jaws" on either side of the link (closest to the clip) while keeping them in-line with the pin--which in turn contacts the puller's threaded post. A couple of quick turns, and the outer plate is removed.
For balance, I use a short Craftsman 3/8" "T"-handle and a shallow-well six-point socket. This configuration keeps the torque I'm applying directly over the pin, thus helping to stabilize the procedure.
This set-up is a cheap alternative to buying a specialty tool. In fact, it's so easy to use, even a caveman could do it! :-) (I remove my chain after every second ride for a thorough cleaning.)
Happy Trails,
TP
'03 EC 300
Thread Tools
Display Modes
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
is there a master link? mountain thumper Enduro Chassis & Body 4 07-09-2008 05:36 AM
How best to remove carbon from PV components? d2w Enduro Engine - 2 stroke 9 02-21-2008 09:03 PM
Periodically remove and re-fit all bolts? stay_upright General Discussions & Announcements 2 01-14-2008 07:56 PM
Another Master-link question FFRDave Enduro Chassis & Body 5 10-21-2006 07:48 AM
