Old 11-18-2017, 11:40 AM
risk74 risk74 is offline
Default XIU Cylinder Head Review
I recently purchased the XIU aftermarket cylinder head for my Gas Gas EC250 from Spain http://www.xiurdi.com/portfolio-item...250cc-y-300cc/. Communication was prompt and friendly, the price was reasonable at around $130 USD shipped and the item arrived in less than ten days.
Squish measurement on the stock head was 1.6mm, with the XIU head the measurement was 1.2mm, so this was positive.
Installation should have been straight forward, but it was actually a pain in the ass. The earlier Gas Gas models have a head stay that bolts to the frame via brackets. There is no provision for this on the XIU head. Fair enough, just had to make a spacer to hold the radiator guards together. On to the next issue, the cylinder head, being much thinner than the stock item, requires the installer to find proper length bolts in order to avoid bottoming the stock ones out in the cylinder, throwing off torque values. This would be easy to miss, as the stock bolts appear to work properly. There was no mention of this from XIU, in fact there were no installation instructions at all. Still, not a huge issue once sorted.
Upon attempting to install the radiator hoses in the XIU head, one realizes that the spigots are remarkably smaller than the stock Gas Gas items. This means the stock rad hoses will not work with the XIU head. Again, there was no mention of this prior or after purchase from XIU. They leave the installer to figure this out as well. After some creative hose solutions, the head was installed. Bolts sequentially torqued to Gas Gas specs and re-torqued after a heat cycle.
As with any 2-stroke getting closer to the optimal squish measurement, a correlating increase in performance was noted. Not exceptional, but noticeable. A good sign. I was happy at this point, despite the installation issues.
Fast forward, after ten hours of use I am not happy at all. Two small coolant leaks were observed on the left side of the head. Upon inspection it was discovered that the cylinder cover casting was cracked in two separate locations, resulting in the leaks. Fortunately this was found before complete failure. An email has been sent to the company with pictures, I await a response and will update as information becomes available.
Old 11-18-2017, 02:21 PM
Moto7man Moto7man is offline
Darn it, that really sucks big time!
―Comedian Lewis Black
-Unknown Sardaukar
Old 11-18-2017, 10:38 PM
EnduroNut EnduroNut is offline
I'm probably missing something here but if you feel the stock head is off why not have it recut... it used to cost me $75
Old 11-20-2017, 12:09 AM
twowheels's Avatar
RB quit doing GG heads here in the US, but Motopsycho should be able to hook a European brother up.
Steven Beane #275
afterhourscycle.com
Old 11-20-2017, 06:33 AM
I know the stock head is off, but RB stopped doing the heads and I needed a spare anyways. RB's turn around time used to be phenomenal, the other tuners that do this type of work, not so much. I can't have my bike down for weeks waiting, with a race every two weeks. This seemed like a good option.
I received an email from XIU, they are going to "check internally how to answer your problem properly". Sounds like the run around. I hate to do it, but if they do not offer a replacement cover, I will have to file with PayPal.
Old 11-20-2017, 09:48 AM
Anders Anders is offline
might be a way of saying nothing, but may also be a way to tell you that they have started working on an answer. I would give them a day or two.
Old 11-20-2017, 11:06 AM
Agreed.
Old 11-20-2017, 02:16 PM
I have been thinking about this head myself, as Xiu-Rdi are the only ones that I have found selling a head with separate inserts for the 200. I have cut the OEM head with good results on my lathe, but fancy parts are always of interest :-)
And after all, these spanish guys have been participating in the design of both Ossa and Gasgas, so I think they know what they are doing, engineering wise. Lets hope this cracked head is a unique issue, and not a sign of their normal quality.
Old 11-20-2017, 07:40 PM
Looks like the head cracked from over torquing of the head bolts.
Old 11-22-2017, 05:48 AM
I was waiting for this. I can tell you unequivocally that was not what happened here. Head was torqued in 4 steps in the proper pattern with a quality click type torque wrench to Gas Gas spec of 18 ft lbs and then checked after a heat cycle. I've dealt with plenty of 2 stroke cylinder heads over 20 years of road racing and never cracked one due to over-torquing.
S3 cylinder head motopsycho87 Enduro Engine - 2 stroke 22 10-22-2016 04:07 PM
Swopping 1997 Cylinder head with 2005 head EC250 Enduro Engine - 2 stroke 10 12-15-2015 10:13 AM
Coolant leaking through cylinder head socket-head bolts. GGRider01 Enduro Engine - 2 stroke 5 10-17-2015 07:38 PM
brushy ride review, bike review, Add on parts review Mazikeen SouthEast United States 6 09-04-2012 05:34 PM
Millenium Tech Cylinder Plating Review Stoby Enduro Product Reviews 16 11-18-2011 07:51 PM
