Old 04-27-2012, 08:46 AM
r00zter r00zter is offline
Question Raising the bars....
Ok guys...need your help again please. I have come to the conclusion that I need to raise the handlebar height on my 2011 300 to better fit my 6'2" frame and long limbs. I need some suggestions on how to do this. I'm still pretty much a noob when it comes to aftermarket changes, so I need some guidance. I'm considering these,
http://www.trialendurodirect.com/pro...DURO_EC_7.html
but I'm not sure if they are what I need. Also, the previous owner of my bike put KTM Nekken bars on it and I'm not sure if those clamps will fit that type because they are for "fatbars" only. My old KTM had fatbars, and they looked about the same size as these Nekken ones, although I'm not positive. Thanks.
Old 04-27-2012, 09:25 AM
Dont want to sound like the bar-raiser-nazi, but i think before you get these maybe get an experienced racer to make sure that you are sitting and standing in the correct position - this position may require some initial adjustments and strengthening before it feels comfortable
reason i say this is that you do not see any pro's with large bar raisers, and i know for a fact that Chris Birch (6'1) and David Knight (6'6) are very anti bar raisers
Some have said the GG is more cramped than the KTM which is why you should get someone to check your stance.
Old 04-27-2012, 10:33 AM
A submount damper would raise them up.
2018 XC300
Old 04-27-2012, 10:51 AM
andoman's Avatar
andoman andoman is offline
+1 on the submount
but...
+2 on body position. If your bars are in the most forward position and you are in the attack position, the Gasser should fit even your size.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 04-27-2012, 12:00 PM
True. Look at all the fast guy's bikes, even big fast guys, and you see low bars.
Old 04-27-2012, 01:17 PM
Points taken. I left a detail out as to why I though I needed to raise the bars. After a long day of riding a couple weeks ago, my thumbs began aching, and haven't stopped. Like mostly in the meaty palm area and down the thumb ligaments. I never had this happen on my ktm 300 so I was guessing it was the bar height.
Old 04-27-2012, 02:35 PM
Whats the sweep like on those? Too much sweep, especially when rotated foward, has given me hand problems in the past.
Old 04-27-2012, 02:48 PM
bowhunter007's Avatar
+1 on the sweep +2 on the body position. I personally just changed out my bars. I did get taller bars +1/2 in. More importantly, they have a sweep that is very comfortable for me. I was sore as hell after my first 3 or 4 rides, when a more experienced rider helped set my bars correctly(at least a starting point). Then watched me ride, and helped with body position. In time I've fine tuned these to get what's right for me.
Old 04-27-2012, 03:50 PM
GG comes with small spacer washers under the bar clamPs. They are about 2-3mm thick I would guess you could stack another set in there to give a slight rise
Old 04-27-2012, 04:51 PM
Wimpy525 Wimpy525 is offline
I'm tall 6'6" and have allways run bar risers untill I got the GG this year. I have now been riding the GG without and probably wont put them in. I did swap the bars out for taller bars with the least amount of sweep back that i could get. Now when I get back on the 525 if feels strange with all the bar rise will be getting rid of the risers. The amount of sweeep back plays heavy on the wrist in my opinon, especially when rolled foward. KX high bend bars are what I run on my 12 300.
Raising oil level 2011 forks? fire1998 Enduro Suspension 23 10-10-2011 11:51 AM
EPA considering raising ethanol to 15% eff General Discussions & Announcements 17 06-01-2011 11:27 PM
Brent Martell : ISDE Fund Raising webmaster General Discussions & Announcements 7 05-31-2011 10:16 AM
GasGasRider.org T-shirts & fund raising coolum74 Suggestion Box 12 03-01-2009 02:41 AM
Bars Dingo Enduro Chassis & Body 8 09-12-2007 09:55 PM
