Old 09-14-2018, 11:03 PM
(F5)'s Avatar
(F5) (F5) is offline
Many race bikes run the pins over the boost port. There's no twist if it's central. Probably little like that.
Does the piston manufacturer specify your bike?
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 09-14-2018, 11:10 PM
(F5)'s Avatar
Hmm, followed that ebay link, strangely one pic is Vertex and the other Woosner. My Woosner is several years old and measured good enough for me to put it back with the same rings after a crank rebuild a couple of months back.
If Vertex list that kit on their website, I'd run it and not worry. I've run pins over open boosts before. Wouldn't do it over transfers.
I've done it over exhaust as a younger lad. Less said about that the better but it didn't end well.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 09-16-2018, 03:35 PM
Desert Silver Desert Silver is offline
Well, the guy who sold me the piston kit called S3 in Spain and they told him that that's the way the 16 and up are made. I also talked to one of the Factory supported Gas Gas riders at the Costa Mesa Endurocross and he told me he's seen the pistons that way so I guess I'll put it in and not worry. Thanks for the feed back.
Old 09-17-2018, 06:50 PM
The last piston I installed into my 2011 250 had the some ring pin configuration over the booster port. I have 40+ hours on it with no issues.
Old 09-18-2018, 02:47 PM
Yeah, everything I've bee finding out is this is normal. I just goes against everything I've ever been taught about 2-smokes. Installing it now and hope to have it running before the weekend. Thanks guys for all of the input. I really appreciate it.
Old 09-18-2018, 03:18 PM
gasgasman's Avatar
Blow- by will be the same as running a single ring piston.
Old 09-19-2018, 02:49 PM
Yes, but the main reason for running a single ring is less friction which allows the engine to rev higher thus producing more HP.
Old 09-19-2018, 04:50 PM
uawelder's Avatar
uawelder uawelder is offline
I just bought a Wossner for my 18 Beta 300RR. Beta changed to a domed piston from flat piston this year. I don?t think $300 for a top end kit is fair, this one cost $150. Here?s some pics. Checked measurements w/ an od mic all were spot on. Received a flat top pro-x that was claimed to be for an 18. It?s measurements were sloppy at best compared to the Wossner w/ skirt .02mm oversized from diameter listed on box. This Wossner is a class act with good machining inside to lighten it up. No machining inside of the pro-x.
File Type: jpg 344432D3-E998-43C5-B62B-A7D0201F42DD.jpg (51.8 KB, 14 views)
File Type: jpg 2B106A7D-5199-45E4-847E-9AEA3788A568.jpg (94.3 KB, 8 views)
Old 09-19-2018, 04:55 PM
uawelder's Avatar
Note the placement of the ring pins on the pic from my previous post. That was the whole point that my previous post was supposed to have made. Sorry, long day.
Old 10-04-2018, 03:47 PM
That's the location of the original ring locating pins. I found that the 2017 KTM 300 has the same ring pin location so I went with it. The proX is a cast piston so there's a lot less machining required in comparo to a forged piston. I'm in the process of doing heat cycles for the break in. I didn't put the ground wire that uses one of the bolts to hold the coil and the Electric starter wouldn't work. Fixed that today and now the button works. lol
2012 and 2011 ec300e Phaeton Used Bikes 0 10-04-2017 10:08 AM
2011 EC300e part out Mick Parts 35 03-16-2017 07:00 PM
First Ride on '15 EC300E celester Enduro Intake/Carburetion - 2 stroke 2 10-08-2016 04:48 PM
2011 EC300E maiden voyage Bobt250 General Discussions & Announcements 24 01-06-2011 01:33 PM
