Old 02-03-2021, 03:29 PM
SpirosZ1000's Avatar
SpirosZ1000 SpirosZ1000 is offline
So sorry for the delay but things with covid and work don't go well.
So after I fixed my starter a friend of mine with a 300 gp 2018 brought the bike to my shop and asked me to fix it also for him.
He brought me a carton full of spare parts slightly used as nothing he had tried in the past gave him the solution.
I first ordered the newer cables from rieju (all 3 of them) as I saw from mine that the old vs the new I had taken where way bigger.
I also ordered the two pinion gears and the small axle that goes into one of them and the new bendix cover. I didn't take the bendix as he already had two of them with one of them being in very good condition.
I kept the stock stator cover even though it wasn't in great shape and the original starter unit.
1) fitted the newer cables.
2) Put new bearings to the 2 pinion gears and press the axle to the one with a tiny bit of permatex steel weld to the grooved area of the axle so that it can stick better with the gear when all the assembly is tighten by the screw in the back.
3) Heating and inserting the axle with the first pinion gear into the cover and then the second. And here lies the trouble with the pinion gears I have ordered (3 times now) from Rieju. The one that has the grooves the starter goes in (all 3) is not the same as the original I have from both bikes. When you put the bearing and you put it into the cover as soon as it goes in place and you secure it with the circlip, it binds and doesn't move at all (in all three samples). As soon as you remove the circlip and back it up a little it's ok and you can rotate the combination with your finger. If now you add the bendix an the bendix cover with the bearings you can still move the whole system with one finger and that's what I wanted to achieve.
So I took the pinion the starter goes on out ( which is the one that's different in all occasions) and put it back to back with the original and saw that the area the bearing shits in is different in height. So I took the gear to a friend with a machine shop and asked him to cut some area from the back of the gear to match the old one.
In my bike which I had bought everything new ( and the stator cover) the first cut attempt (0.25 of a mm) was enough to get the job done and YES my system worked and still works even with the stock starter motor.
In my friends bike I though I had the solution ready and went straight away for the 0.25 cut but went I put it into the cover I still had the binding. So off again and by the look of it I want it another 0.10 of a mm to sort it out but again I wasn't ready. That made me thing that maybe the older stator cover are not the same as the newer from rieju. Anyway a third cut and I was game on. Put it everything back in place and I could rotate the whole mechanism by my finger with minimal effort.
Placed it on the bike and it fires up like nothing ever happened.
I want to add something up in this stage. My bike has the wet mod and I believe it works with less noise and it's always lubricated. On my friends bike he wanted to keep it as it was. We both have skyrich lion battery of 270 cca
but for some reason his battery which had stayed on a self for about 2 years doesn't want to play nicely and gives that clunking noise half the times you press the button when cold but it was just the battery.
We run the stock starters both and when the temperature is below 10 celsious both the battery and the starter don't like the first button.
I have already order from ebay the ktm starter units to reverse polarity because before I fried the arrowhead I had bought, I used it before I get the system to work as I liked and it worked way better. The new rieju unit also does the job but is way more expensive.
I hope I gave you a possible solution to your problem.
For me has worked both times now but truth be told it costed way to much money in parts and time.
I believe the problem lies in tolerances and poor design and the fact that riejus come and work ( or at least I hope they work and keep working) is due to many complains about this and the attention they gave to this.
As for gassers I believe they were assembled by chance because I have already pinpoint few more things that I shouldn't have come across because I never did with no gasser before and they are things that haven't changed (theoretically).
Gas Gas EC 300 2006
Gas Gas EC 300 R 2015
Gas Gas EC 250 GP 2018
Old 02-03-2021, 06:04 PM
(F5)'s Avatar
(F5) (F5) is offline
Sounds like you've done some good work there.
Next someone needs to do a sticky with pictures and steps.
Makes.me more confident in buying a newer GG when I can swing the money together.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 02-16-2021, 11:56 AM
I will do that in the near future with the old parts as an example plus some photos from the pinion gears difference.
I am currently in the process of selling the bike to raise more funds so that I can start importing Rieju bikes here in Greece and also their spare parts. Meanwhile I am trying to find time to setup the e-shop for both parts and accessories and if everything goes well bikes too.
Gas Gas EC 300 2006
Old 02-16-2021, 12:11 PM
blitz11's Avatar
blitz11 blitz11 is offline
Good luck with your dealership/distributorship. Once you have a website, be sure to include the URL. I would like to check it out.
Old 02-17-2021, 02:43 PM
Will do that. Let's just hope that goes well with this pandemic because things aren't so good for the past 12 months here and everything goes really slow.
Gas Gas EC 300 2006
Old 02-21-2021, 12:14 AM
gg3's Avatar
gg3 gg3 is offline
Originally Posted by gg3 View Post
UPDATE- Bushes didn't work. Considered selling it as immensely pissed off, but still love riding it. Did the conversion to 24v & it starts supper fast cold or in gear. Will report back after a couple of rides. Hopefully it will not destroy the starter motor or wreck the pinion/bendix gears.
Update,Rode today & started the bike about 10-12 times including in gear without any problems.Both battery's still have plenty of charge.
So will call this a win & starter problem fixed.Also rode a 2021 Husky TE300tpi,wow awesome bike.Still prefer the KYB gear though.
Old 03-03-2021, 03:32 PM
Reinaldo Reinaldo is offline
Smile 2018/19 e-start problems solution
Hello to all gasgas lovers and users,
Like you all I struggle with problems in the starting system and try all to fix it .
Even the 24v mod , that by the way works fine with one 11.2v Rc battery, the only problem is that the rc battery doesn't like to swim in deep waters and I kill it in one ride !!
Chinese motors , as3 cover, bigger wires , 24v I try all and it was frustrating because nothing was robust enough for the demand of one hard enduro training.
But I dicided to talk with you guys because the solution is now in the market. Rieju realize that the parts are from a bad engineer and for sure contract new ones and solve the problem .
To solve the problem you need the new starting motor ( iqual from the outside but very difente on power delivery ) , the bendix cover ( with needle baring ) and if you want can also by the new bendix with the roller bearings and bushing kit ( in my case I don't buy it ) .
Mount that and you immediately feel the extra power of the starting engine , it fire up always at the 1 atemp and with no delay .
Hope this can help you all .
Best regards
Reinaldo
Gasgas Ec300 six days 2019
Old 05-23-2021, 03:19 AM
Gez Gez is offline
Mine stopped working again this weekend. Went from starting to nothing, not even a click. I'm thinking relay at this early stage.
Old 05-27-2021, 09:34 AM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
Best regards
Reinaldo
How did you find all the part #'s that you discuss above? Thanks
2012 - XC 300 Racing
Seattle, WA
Old 05-27-2021, 02:36 PM
farmerj's Avatar
farmerj farmerj is offline
Stu,
Post #36 and #78 show the bendix cover and the number (EE80130GG-CBR-2). I mention them because there is some other good info. earlier in this thread (and one post pointing to a TT thread) that just about covers it all!
If you order the Starter Motor and Bendix cover from your Rieju Dealer, as long as they are ordering through Rieju you will get the right stuff - and I'm with Reinaldo, they are improved parts (even the pinion gears in the new bike have been improved I am told).
The new Starter Motor and Bendix cover did it for me - I'm getting nearly instant starts, and the bike starts from cold (20-30 hours with these parts so far).
I would try that before the added cost of a new Bendix w/bushing (and before trying a 12V system).
FWIW,
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Wet mod for 2018 starter GG221 Enduro Engine - 2 stroke 20 12-05-2022 07:51 PM
2018 ec300 starting issues! Wtf. Steveheritage General Discussions & Announcements 17 09-05-2018 07:52 AM
05 300ec Turn Signal Issues natem77 Enduro Electrical & Wiring 1 04-05-2017 05:14 PM
Looking for electric starter for 300EC 2012 oran "Wanted to Buy" & "Want To Trade" 0 01-09-2016 02:33 AM
Electric Starter pictures 2011 300EC gasgasquebec General Discussions & Announcements 70 12-04-2011 10:01 PM
