Old 12-17-2018, 05:56 AM
eralha eralha is offline
Default Weak clutch disc cover, EC 2018
Hello guys,
Just to let the owners of EC 2018 to protect the clutch discs cover, this thing looks like its made of paper 2mm aluminium, my bike fell on its side while on the stand and it did this job: https://1drv.ms/u/s!Aq0Qx6sqeizHgplqJ8zYSJ_OLVCAkg
I got stuck on the trail with this in hands, i had to pull the bike out of a nasty single track to the nearest road.
Protect this cover so the bad luck don't knock on your door like it did to me.
Cheers.
Old 12-17-2018, 08:23 AM
RudolfHucker's Avatar
That is bad luck. I would have expected the normal damage caused by the rear brake lever being punched into the case. That's a much more difficult area to protect. At least you didn't suddenly lose your transmission oil from a hole low down on the case.
Did the case break up and shed pieces into the engine?
Old 12-17-2018, 09:29 AM
The engine was turned off when this happened, and i did not turned it on again until i dismounted the cover. I just got little bits of dirt on the clutch plate, nothing major.
this cover needs something like this: https://www.motocrosscenter.com/shop...-hog10056.html
Old 12-18-2018, 02:12 AM
Ouch that's bad luck really. The engine covers on other bikes are also very thin, especially all KTM smokers from 2017 on.
On my GG/18 I had the Rekluse cover which seems to be at least a little bit less prone to breaking. But I am looking for a cover protector for my 2019, didnt find anything good yet.
Dont like the one you show, they act like an inuslation and keep the heat saved.
Old 12-18-2018, 03:17 AM
shawbagga's Avatar
P-Tech do a billet ally one Doc
'18 Gasgas XC250
Old 12-18-2018, 03:18 AM
shawbagga's Avatar
Originally Posted by eralha View Post
Hello guys,
Cheers.
Footpeg has copped some abuse too by the look of it!
Pardon my ignorance but why do you(& lots of others) run the peg pin upside down?
'18 Gasgas XC250
Old 12-18-2018, 05:33 AM
Yep the footpeg got bent on another occasion, got hit by rock on a narrow passage.
The clip came like this from factory i didn?t changed it.
Old 12-18-2018, 05:36 AM
shawbagga's Avatar
Ok. I always run them main pin in from the top so even if split pin falls out gravity should help keep main pin in.
'18 Gasgas XC250
Old 12-18-2018, 05:41 AM
Anders Anders is offline
I guess I 'm one of the others :-)
I run the peg pins upside down because I think that it should be as smooth as possible under the footpeg, as they slide over obstacles. I don't know if it has any practical significance, but that's my reason.
Old 12-18-2018, 01:21 PM
Many thanks! Will try to get one
2018 ec300 brake disc Gottsell Enduro Chassis & Body 1 08-28-2019 06:28 AM
Rekluse Clutch Cover for 2018 MY Jacob 'Berg Enduro Engine - 2 stroke 10 05-30-2018 07:32 PM
Front disc cover hamilton Enduro Chassis & Body 9 02-20-2016 06:21 PM
Front Disc Cover sammyj18 Enduro Chassis & Body 5 06-24-2008 06:34 PM
