Old 05-07-2017, 03:02 PM
Avoided_asphalt's Avatar
Avoided_asphalt Avoided_asphalt is offline
Default Forks on a 99 model. Can't find a manual
Hi, any of you guys have a link to the (Conventional) Marzocchi forks on this old bike please ?
Old 05-08-2017, 12:15 AM
webmaster's Avatar
Administrator
http://marzocchimoto.blogspot.com/
Scroll to the bottom for parts fiche and oil levels. I see manuals for sale on e-bay.
Full name for the fork is marzocchi 45mm magnum - might help you on a google search, etc.
Old 05-08-2017, 02:40 AM
Smile
Many thanks Jeff and for all your work keeping this great forum going
Old 05-08-2017, 09:35 AM
slocalspode's Avatar
I have a 20 page .pdf file for the 45 / 50 Magnum forks.
PM me an e-mail address and I will forward it to you.
I sent this file to Jeff (webmaster) a year or two ago to put in the
files section. So far he has not posted it.
Cheers.
Old 01-15-2018, 04:17 PM
Default Marzocchi Magnum 45mm bushings sourced
Bit of an update about 9 months later (slowly getting there !)
Fork seals are same as 1996 KTMs which also used the Magnum 45mm forks (but see below)
Fork bushings for 99 and 2000 EC models, thats the teflon coated ones, are available from GasGas motos in the UK -
part number BE25714134 "Botella" (The bush in the bottom part of the fork)
part number BE25714134 "Barra" (The bush in the upper part of the fork thats bolted into your triple clamps or "yokes") [Yokes is a UK only word I think]
I don't know what the "Italian ?" words mean, inner and outer I guess.
I checked out the 2000 model parts list and these bushings are the same for '99 and '00 bikes. My forks are from a 99 Gas Gas EC 200 (but forks fitted to an 02 EC 300).
Just trying to sort some new fork springs and we're ready to go
FWIW - By mistake I bought the Innteck bushings part numbers SKTE45M and SKTI45M but these don't fit, are for earlier model Marzocchis such as a 1996 KTM 250/300/360 SX
Worth tracking these parts down as these forks are really good when set up right IMHO
Old 01-15-2018, 04:19 PM
[QUOTE=Avoided_asphalt;180932]Bit of an update about 9 months later (slowly getting there !)
INCORRECT, sorry its BE25714111
Old 01-21-2018, 05:42 AM
Default Marzocchi Magnum 45mm forks
OK sad bloke replying to his own post again but its taken hours tracking down parts etc and thought I'd share this so others can save time.
Gas Gas don't have the fork springs in stock. Much googling etc later I came across Eibach springs. The Eibach 979 series is apparently the correct spring but they don't do that any more. Their supplier and I talked about the sizes etc and it turns out that the Eibach 988 series is just about the same size, so I'm trying those.
Original spring size is approx 470mm long x 38mm diameter (18.5" x 1.5")
HTH and good luck I got there in the end.
Old 01-21-2018, 02:16 PM
Call www.cannonracecraft.com. They will make any springs you want. You will need ID, OD and length in mm of the existing coils. Also You’ll have to tell them the weight of of spring you want.
They are reasonably priced especially for a custom spring.
I’ve used them a couple times and have been happy
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
Old 01-22-2018, 03:03 AM
Tiddlesrx7 Tiddlesrx7 is offline
http://theoldwoolshop.co.uk/mz/Front_Forks_Manual.pdf
This is the one I used when looking at mine.
Help ?? Need to find someone whom I owe Stoby General Discussions & Announcements 5 08-24-2016 07:46 PM
CL find desertgasser300 Used Bikes 4 05-10-2013 11:25 PM
ec300 2000 model user manual cjcj121 Enduro Other... 4 10-09-2010 12:54 AM
manual for 99ec200 front forks? bitoman Enduro Suspension 8 07-17-2009 07:40 PM
gas gas ec250 parts manual, 2002 model thenutt General Discussions & Announcements 3 05-05-2009 12:05 AM
