Old 01-02-2018, 07:56 AM
But he just said that the PV rod is stuck up so it not allowing the PV pivot to travel back down which would drastically kill low end.
Old 01-02-2018, 01:55 PM
(F5) (F5) is online now
Oh, so now I'm now like expected to like read and comprehend stuff?
That's not how I roll.
. . , and I had an idea come to me since first reading and didn't check later posts.
My new years resolution is to continue being awesome.
Old 01-02-2018, 04:39 PM
Talking
Happy New Year!!!!
Old 01-28-2018, 12:01 PM
Joper Joper is offline
Did you fix the problem with the PV and does it run good again? Last few rides I have noticed the same symptom on my ec200-13. It lacks bottom end power and I need to slip the clutch a lot to pick up rpm, then it runs OK. No play in PV linkage and it closes as it should.
Been fiddling with jetting also but this feels like something else. Currently running:
Pj - 40
Mj - 180
Needle - CCL in middle position
Pilot screw - 1,25 turns out
Hope I can fix this soon
Old 01-30-2018, 12:17 PM
Checked some things today but still nothing obvious. Compression 175-180 psi, no play in pv (took that away when changing piston).
Seems weird that it should be jetting since it has appeared gradually last few rides. The plug is still pretty dark so it shouldn?t be a lean condition.
Does the spring in the PV actuator get loose after time and eventually need to be shimmed for better low end? Read that some guys had good luck using a shin but it seems strange that it would change over time?
Old 02-08-2018, 12:16 AM
Not much activity here but ill continue posting my results for others to find
Did some testing yesterday to see if it was a lean condition. Tried PJ42 and also lifting the needle one notch, now at 4 from top. I havent mentioned my gearing wich is 13-50. AS is about 2-2,5 turns out after some adjusting while riding.
I think it ran better in the beginning, only rode for 20-30 minutes with no real wot passes. Had some rich blubber because of the needle being raised but the bottom seemed better for the first 15 minutes i think. Then gradually the bottom end power got worse. Hard to know exactly but it felt like i couldnt lift the front in the low rpm in the end.
If Im in second gear at a low pace and open the throttle (not fully but as if you were lifting the front over a log) it respons bad. It doesnt do the "bhaaaa" as if it was way to lean but theres just not much power. More spooge now and the plug is pretty black.
Old 02-09-2018, 07:08 AM
gasser's Avatar
gasser gasser is offline
Another possibility may be the wrong oil for the way you ride. Here is what I mean. Oils are made with different flashpoints. Flashpoint is the temperature where the oil starts to burn. Too low a flash point and the oil won't give adequate protection. Too high and it will accumulate ,more and more in your power valve and pipe till the bike won't hardly run. Lugging the bike in slow, technical, terrain doesn't let the top end of your motor get hot enough to burn off excess oil like it does at higher revs. Motul is one of the more popular brands of 2 stroke oil sold in bike shops here in the states. Motul 800 is the easiest to find and it's flashpoint is 252c/485f degrees. Motul 710 and Motul 510 have a much lower flashpoint at only 90c/195f degrees. I can't run the 800 where I ride but the 710 and 510 are fine.
Old 02-09-2018, 07:25 AM
Thats a very intresting point since I do run the motul 800 oil and my local singletrack is very tight and technical and I only get out of 2nd gear a couple of short sections over a 7-8 km track. I will go back to 40 pj and needle in the middle and try motul 710.
I also noticed yesterday while changing transmission oil that it was quite dark. Usually if the crank seal is bad it sucks in trans oil and not the other way around? Maby its just because I have had to use the clutch quite much with the bike being low on bottom end power.
Thanks for the reply! I?ll report back with result
Old 02-10-2018, 12:44 PM
Today I rode some tight technical singletrack again. Weather here in Sweden is cold with -2 degrees Celsius (~28 in Fahrenheit). Tried pj38 and dropping the needle one notch since my plug was black. Seems lean for the weather but the plug says different? Also adjusted the float level more accurate after making a measure tool. Couldn?t find motul 710 or 510 to test if that?s the problem but I did have some shell advance vsx that I rode with instead of the motul 800.
Good idle and a bit less spooge but still runs down the silencer a bit. Still bad bottom end. I don?t even know how it should run anymore since I?m getting used to this..
Maby my silencer packing is saturated with spooge now and that stuffs it and not letting it breath? I?m gonna change it out anyway but could that do this much on the running of the bike?
I also checket the movement of the PV on the left side. It turns about 1/4 of a turn and doesn?t seem to open to early when reving it on the stand. Does the amount of opening seem right?
Old 02-10-2018, 03:14 PM
barossi73's Avatar
If you carefully disconnect the actuator rod(top)you can rotate the power valve with fingers to check its moving freely through the entire range.I say carefully because others have found the small stud can crack its weld on back of actuator plate.The safest way is to heat the nut to release the nylock (but youll need a new nut).From memory the pv should open fully once it starts to move,its basically either full open or full shut rpm dependent.(it may flutter a bit if you hold rpm right on the "switch point")
2013 ec200r
Wtb 03 250 bottom end papagasgas "Wanted to Buy" & "Want To Trade" 0 08-30-2015 02:44 PM
'05 125 bottom end marshalls113 Parts 0 04-14-2014 08:16 PM
bottom end condition? knobbyboy Enduro Engine - 2 stroke 10 01-12-2013 06:32 PM
