Old 11-09-2012, 09:45 AM
GasGas's Avatar
GasGas GasGas is offline
The '12 cover is fine after being lapped flat on a glass plate, along with the ignition cover. Mine weeped a little stock now no issues. That said, you have to wonder if the oil scavanging vanes on the inside were ever tested since GG was so quick to abandon them. I suspect not and that it was a "shotgun" approach to solving the problem. Honestly they can't hurt, but my older bikes with the alloy covers were just as good. I think its the basket/pressure plate more than anything. Actually they were always good until '11.
A new basket from Rekluse will fix the clutch squawk and vibration for the most part. Definitely an oil flow problem IMO. The new basket must pick the oil up much better. The clutch would be pretty dry between the plates before the new basket.
2018 EC 300
Old 01-05-2013, 07:48 AM
Anders's Avatar
Anders Anders is online now
Originally Posted by twowheels View Post
Check and see if the part number cast on the inside has a 'Mg' preceding it.
I had a quick look at my 06 EC200 clutch today. The cover has a "Mg" preceeding the cast in part number, so I guess the magnesium cover is nothing new.
Sent from my OMNIA7 using Board Express
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
DIY Clutch Cover Gasket unclejosh Enduro Engine - 2 stroke 8 03-22-2012 09:11 AM
RMW Clutch Cover Rod Overstreet Enduro Product Reviews 2 01-24-2011 10:51 AM
Clutch cover gasket ? cbutler Enduro Engine - 2 stroke 3 06-20-2010 11:29 PM
clutch cover gasket to big? rupecopp Enduro Engine - 2 stroke 2 06-10-2008 03:08 AM
