The race of your life, and only one spare wheel
Given the choice of only one, would you choose to have on hand a spare front wheel or a spare rear wheel?
Tell us why. (It would be a desert race.) |
I would say front wheel. I think it would get damaged easier because it is larger. If you hit something it's with the front wheel and the rear wheel only follows
A rear wheel has both brake and sprocket, so one more system that could fail or stress the whole system to fail. My only wheel failure ever was a rear.
Rear tires wear faster. An optional rear tread pattern might be nice to have mounted ready to go if you aren't sure what conditions will be. If the front fails, you can just wheelie all the way to the finish. I'd bring a rear. Which probably means front is the correct answer. just guessing... -dean
Thanks to FLY Racing. |
Rear. The front is usually floating. The rear takes the abuse. Are you planning for the future?
jeff '00 XC250 (mine) LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion. '04 EC250 (the kids) (he can do his own mods haha!) |
None, I would use Tire Balls.
Blanco Current ride: 2009 WR450 Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F |
Front. Rear is stronger. Ask people of all the flats they have had, did they have more front or rear? That should be your answer. That is unless you plan to ride far enough to wear out a rear tire.
Thank you for the responses.
I plan on going somewhere between 675 miles and 1100 miles. I'd get both front and rear, but if I keep doubling my expenses, I'll run out of funds half way through my parts list. . |
that's a lot of miles on a non dot tire.... i think a rear would have no knobs left after that many miles...
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
Forget tires, you need to bring an extra ass!
I'm considering running these tires http://www.dunlopmotorcycle.com/tire...tire.asp?id=14 with a mousse in the front and a heavy duty tube and slime in the rear. The advice I've been given is a rear mousse will melt at high speeds. What I can't quite figure out is if the melting rear mousse also applies to iron man speeds.
I'm still searching for information. At some point a call to Michelin (the maker of the mousse) will be in order.
2011 xc250r The fight is not won in the ring. It is won on the road and in the gym. |
Front wheel bearing life | roostafish | Enduro Chassis & Body | 11 | 12-27-2010 11:55 AM |
GasGas parts, 2nd life | Loosenut | General Discussions & Announcements | 1 | 04-10-2009 06:48 PM |
515 real life questions?? | Cruiser | General Discussions & Announcements | 21 | 07-25-2008 12:31 PM |
Spare Parts | coolum74 | Australia & New Zealand | 8 | 07-01-2008 04:56 AM |
where have you been all my life.................. | 450sx | General Discussions & Announcements | 3 | 05-01-2008 01:04 PM |
