Old 01-28-2015, 05:22 PM
JP4's Avatar
JP4 JP4 is offline
Originally Posted by stay_upright View Post
Also to set up my '05 I adjusted the high speed compression nearly all the way off and it works beautifully - the standard model won't have the HS compression... I like my bikes very soft...
If it has the Sachs shock it should have a HS compression clicker - mine does.
I believe that it is only the Reiger shocks on the GG that do not have HS compression adjustment. For that matter, I think every contemporary shock other than the Reiger has HS compression adjustment - not talking OE on a DR200 etc.
Old 01-28-2015, 05:52 PM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
Originally Posted by 95jersey View Post
In the US they only import the racing model.
I think one of the 'issues' that in the recent past GG is that would send bikes that didn't really have the proper components, the ones that were promised from the factory to the importer.
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 01-28-2015, 06:06 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Looking at the compression adjuster exploded view it appears to be an all compression adjuster, no restricted flow so if you turn it down it gets softer throughout, this is how it feels as well.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 01-29-2015, 12:52 AM
n_green n_green is offline
Where did to get the exploded view?
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 01-29-2015, 06:32 AM
stay_upright's Avatar
stay_upright stay_upright is offline
So it's not like a bleed screw type adjustment to bypass the shims then?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 02-01-2015, 10:30 AM
elemetal2 elemetal2 is offline
What I read about the Reiger is it has truly independent piston bleeds for the compression and rebound (unlike the Ohlins). I know you can buy a port block from Ohlins that will isolate them but that isn't standard. Typically the compression adjust will also effect the rebound which is more of an issue if you have to run heavy springs.
2005 to 2011 transformation questions jcborden Enduro Chassis & Body 20 05-23-2013 11:05 AM
May Be Getting a GG But I Have Some Questions York Racing General Discussions & Announcements 6 12-02-2011 09:34 AM
Questions and help please? darrenrd General Discussions & Announcements 4 08-01-2011 11:24 PM
AC and DC Questions speedy08 Enduro Electrical & Wiring 2 05-07-2011 10:34 AM
Ec 200 Questions rippn450 General Discussions & Announcements 4 11-27-2007 09:52 PM
