'12 Plastics
I had a quick search but cant find the thread on making the rear side panels tight! mine are starting to get a bit loose so what have others done?
Does this rag smell like chloroform? |
I drilled hole in to middle of that clip wich gets to subframe. drill it as near sidepanels side as you can. Then zip tie it to subframes hole from inside of panel.Thats what I've done.
There is no such thing as bad weather! Only riding gear is improper or insufficient When it hurts you know you're allive! Gas Gas EC 300 Factory Racing 2012 - Ohlins TTX both front and rear - Rekluse Core EXP 2.0 + Rekluse clutch basket - Scalvini full exhaust system - S3 Head - Trusty adjustable PV cover That was ultimate setup for me... Now trying something else for a while... |
Good idea thanks.
gas gas plastics | randy | General Discussions & Announcements | 2 | 11-07-2009 02:41 PM |
99 - 02 KX plastics on GG 05 | brains | Enduro Chassis & Body | 7 | 01-03-2009 04:19 PM |
gas gas plastics | johns2394 | Enduro Chassis & Body | 1 | 12-09-2008 06:44 AM |
Where to get plastics 98 EC - UK | jazzy | Enduro Chassis & Body | 0 | 09-24-2008 04:43 AM |
