Old 10-25-2013, 03:34 AM
ilovemymami ilovemymami is offline
Exclamation Cant find rear spring for my GasGas
Hi, i got the EC 250 Cervantes REPLICA 2011 bike, and i think there is a 888 ohlins ttx shock, i ordered from enduro engineering the spring they have 5.8 rate
[i have been told that it will fit my weight (105KG)] but the spring not physically go on to my shock, i checked the diameter and found out that i need a 68 mm diameter spring. where can i found online store that sell that?
Thnx, Daniel.
Old 10-25-2013, 03:38 AM
Anders Anders is online now
Thnx, Daniel.
I presume 5.8 is quite OK for your weight.
Your Cervantes has a Ohlins TTX shock. You need a spring for that shock, any Ohlins or Gasgas supplier should be able to help you.
Where are you located?
Old 10-25-2013, 03:51 AM
Default : (
i'm located in israel, cant find any help here, looking for some online store.
The TTX shock (which you have) has a larger ID than the 888. True story. I have both shocks, and unfortunately have had to buy a few springs for each as well.
Old 10-25-2013, 04:05 AM
In that case I would suggest
http://www.motocrosscenter.com or http://www.greenlandmx.com/
Both shops are in Spain.
How to find the GasGas manuals... MattR General Discussions & Announcements 60 10-11-2022 09:20 AM
GASGAS apparel. Where can I find some? fire1998 General Discussions & Announcements 2 09-06-2011 06:40 PM
Where to find a sachs shock spring? bergerhag Enduro Suspension 3 06-16-2010 01:25 PM
