Gas Gas MC 125 questions
Hello!
I just bought an used Gas Gas MC 125 from 2005, I have a few questions for: Does the plastic from the 2007 model EC fit on my bike? (I am considering buying a polisport kit, if it fits) Does my bike share rear sprockets, with other Gas Gas models? Is it true that I can use a Honda piston on my bike? My fork is a bit leaky, what will I have to change to make it tight? I am also considering buying the FMF Gnarly or the Dep 2 stroke exhaust - Which one would you choose? Will I have to adjust the carburator if I fit another exhaust pipe? And can I use the stock silencer? Hope you can help me -Best regards, Morten D. Nielsen - Denmark |
Plastic requires upgrade to the '07 subframe/tank/seat.
Rear sprockets are the same as other GG all years (as well as Husky) Countershaft sprocket is 125 specific. Not sure about the '05, but the '01/'02 can use a '00 YZ125 piston kit Hinson clutch basket for a Honda CR125. Fork is same as larger GGs, change seals. FMF is good for more bottom on the 125, good in woods. We don't get the DEP pipe here. |
Thank you, does anyone have a 100% correct answer about the piston? - Its my biggest issue at the moment. |
Just found out that my bike use the same piston as the earlier models, does it also share the Yamaha gaskets? (for the cylinder)
I 've used the YZ 125 pistons with no problems. But I would stick with OEM gaskets from GasGas. The yz base gasket is not the same.
2k-2/2k-3 Questions | F_G | Enduro Electrical & Wiring | 20 | 09-13-2009 05:31 PM |
EC 200 questions | eddy field1 | General Discussions & Announcements | 0 | 08-31-2009 03:17 AM |
GG FSR 515 Questions....what to do | pbspecial | General Discussions & Announcements | 9 | 04-14-2008 09:11 PM |
Ec 200 Questions | rippn450 | General Discussions & Announcements | 4 | 11-27-2007 09:52 PM |
Some gas gas questions? | ktmbigfan | General Discussions & Announcements | 12 | 09-27-2006 07:38 AM |
