Old 03-17-2018, 12:58 PM
Moto7man Moto7man is offline
Originally Posted by slodrew View Post
It needs a little love like my bike.
―Comedian Lewis Black
-Unknown Sardaukar
Old 03-25-2018, 06:46 PM
Ok, I got the piston unstuck from the cylinder after letting the cylinder soak in PB Blaster and Kano Aerokroil Penetrating Oil for about a week.
The piston was stuck at almost TDC. The head, and the piston looked good but there was surface rust on the lower cylinder skirts.
-Unknown Sardaukar
Old 03-25-2018, 06:53 PM
Barrel
The piston didn't look too bad at all.
There was a lot of carbon on the piston and in the exhaust port.
After a quick cleanup, this is what the piston looked like,
-Unknown Sardaukar
Old 03-25-2018, 07:00 PM
Intake
Reeds looked great, some oxidation on the cage.
Another shot after unsticking the cylinder.
Stator
-Unknown Sardaukar
Old 03-25-2018, 07:10 PM
A measure and you might get away with a hone and new ring if no ugly force was applied. No point replacing serviceable parts.
Old 03-25-2018, 07:15 PM
I could not find direct damage from engine failure or even wear, just neglect from sitting since 1991. I drained the oil and it was debris free just very old. Ok, here is the bad news.
The rod and main bearings are stuck too. But no sign of apparent direct damage or wear.
I decided to pull the motor for a full rebuild. I pulled the swingarm shaft 3/4 of the way out and removed all the engine mounts except the bottom one which the nut came off the bolt but the bolt would not move. I turned the bike upside down and hit the bolt with PB Blaster and some heat, then my impact wrench, the bolt turns freely now but the bolt still will not back out. I am going to let it soak for a few days.
-Unknown Sardaukar
Old 03-25-2018, 07:30 PM
Some interesting things.....
Good sealing side access airbox that completely comes off with 3 bolts and an original Klotz sticker.
Full floating rear brake.
Dual arm front brake. front forks have compression adjusters on the bottom.
Like a time capsule, a Sunstar sprocket logo that I haven't seen since I was 17 years old.
-Unknown Sardaukar
Old 03-26-2018, 10:59 AM
I only gently rocked the cylinder and the cylinder broke loose. The base and head gaskets were inract.
-Unknown Sardaukar
Old 03-30-2018, 09:16 PM
gasgasxc gasgasxc is offline
No No No
That thing shouldnt even be in the same garage as the CR.
Old 04-02-2018, 01:43 PM
Originally Posted by gasgasxc View Post
No No No
LOL,LOL, I don't the CR likes the RM very much.
-Unknown Sardaukar
94 CR 250 Ground Up Restoration IMS Wide Ratio Transmission Issue Moto7man All Other Bikes... 146 01-28-2018 05:57 PM
1994 CR 250 Restoration featured on Dirt Bike Magazine Webpage Moto7man Pictures & Videos 8 10-28-2017 09:12 AM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
