Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 05-04-2017, 10:08 AM
Moto7man Moto7man is offline
Originally Posted by Zrt1200 View Post
I have been thinking about it lately. When I bought my 05 the guy had a rekluse I could have bought for $300. I kinda wish I would have bought it now.
This is a RMS-6013D Rekluse EXP 3.0 Clutch and retail is $399.00.
―Comedian Lewis Black
-Unknown Sardaukar
Old 05-04-2017, 02:17 PM
Default Youtube Video of Another Person's 94 Cr250
This is another person's 94 cr 250 that I saw on youtube, the motor sounds kinda raspy but decent.
https://www.youtube.com/watch?v=gAsUavbdjfI
-Unknown Sardaukar
Old 05-04-2017, 07:27 PM
Zrt1200 Zrt1200 is offline
Where???
Old 05-04-2017, 08:21 PM
rvangeel rvangeel is offline
Sorry to go off topic but this talk of the $399 rekluse has been talked about before. This is the CRF450 part #. Is there any issues with getting the clutch adjusted properly? I remember something about custom washers used as spacers to get the right adjustment?
Old 05-05-2017, 06:53 AM
Thanks. As now I know why when I searched it showed a CRF450. I did a bunch of search's and found all kinds of info on installing the Honda rekluse. A couple washers is easy. But if I needs to use a rekluse clutch basket to make it work smoothly thats another $250. As for using the Honda rekluse. Watch the video.
https://www.youtube.com/watch?v=LsqKrh8fmZk
http://www.gasgasrider.org/forum/showthread.php?t=15126
Old 05-05-2017, 07:41 PM
As you can tell from the bottom thread, I did a lot of work measuring the Honda Clutchpack and making it work in my Gasser. That same Clutchpack is still in my gasser and it still works perfect. You don't need the Rekluse Basket, the stock one is fine. I only use the Rekluse basket in the my gasser because I am a too picky for my own good. The stock gasser basket squeals a lot but works fine. the Rekluse is very quiet. In my 95 CR 250 My stock basket was "junk" so I had to buy a new basket so I just bought a Rekluse Basket.
-Unknown Sardaukar
Old 05-05-2017, 07:57 PM
I spoke with the techs at Rekluse yesterday. I asked them if I have to remove the clutch cover on the Honda to set the free gain because my 94 Cr 250 doesn't have a hydraulic clutch and slave cylinder like my gasser. The tech said no, he said on this model Rekluse auto clutch that the free gain could be set using the clutch cable adjuster only.
I haven't been able to verify that because the build is in progress. I will post updates when I know more. I don't know if this model Rekluse would work in a gasser using the Honda Pack with Honda fibers and the Rekluse steels plus the extra Rekluse steel at 1.55 mm(check the steel measurements on the bottom thread.)If you match the Honda clutch pack (including the Rekluse Ring) total height exactly to the stock gasser clutch pack total height and there are not any fitment issues it might work fine.
As I do the build I will post more updates on the Rekluse installation.
-Unknown Sardaukar
Old 05-06-2017, 07:44 PM
Thank you for the info.
Old 05-07-2017, 09:17 AM
You are welcome! Here is the Rekluse install video including the details of cable adjustment for the auto clutch. Just scroll down to the EXP section for cable actuation for coil spring models and click that link. https://rekluse.com/support/videos/a...upport-videos/
-Unknown Sardaukar
Old 05-08-2017, 08:56 AM
Default Correct AS I Carb and Some Progress
Yesterday I received the correct ASI Carb. I pulled it apart and check the jets and needle. It came with a #7 slide, 170 Main, 55 pilot and DDJ needle. I am running an FMF Fatty with an FMF SA, FMF recommends 175 Main, 52 pilot, R1369N Needle at 3rd position with airscrew at 1.5 out.This is what it looks like,
-Unknown Sardaukar
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
