#11
I searched and its Napa part # AR-614
Dont follow me, You wont make it. |
#12
Missouri,USA.You can order your relays online.Go to napaonline with your part numbers.
#13
Don't get mad due to lack of responses to your question. This site has been down for a couple of days, and as someone already said it's mostly bike guys here. I just read your post because I had no idea what a "wild" GG was. I thought you meant it was running wild in some way. I've owned 2 GG bikes, but have never seen a GG quad here in the states. Didn't even know they made quads.
I have asked a bunch of questions here and always gotten good input. As for NAPA, it's a quality auto parts house in the states that usually has staff that care enough to actually help you match parts, and cross reference. One of those places that charge the customer a bit more but it's worth the price if you need good parts and help. Jeff. |
#14
thanks (nick) much appreciated, bikes giving me alot of agro at min put 4 litre of oil in it and its not using it or burning it and its not in the cooiling system... only done 18 miles and its vanished!! think im going to sell it as spares or repair ive spent more time fixing it than riding it thanks for allinput every one
#15
just a quick update for anybody who might have a similar problem, turned out wasn't a relay was coincidence. i had a broken wire on the harness took it all of and bench tested it was the second to last wire i tested and could have been repaired on bike sods law!! a short earth wire running from the wiring harness multiplug to the ecu was broken but touching causing a intermitant fault. paired with this is what i believe to be a faulty coolant temp sensor with the resistance values i got from another member bike now revs and runs properly untill its upto temp then slows down and wont rev properly
Gas Gas 250 wont tick over | Wilksiee | Enduro Engine - 2 stroke | 11 | 03-24-2012 05:20 AM |
Why wont Rekluse make a EXP for the GG. | seamonster | General Discussions & Announcements | 17 | 03-04-2012 08:20 PM |
Front end wont turn | Malcolm | Enduro Suspension | 4 | 05-23-2011 01:56 PM |
02 EC 300 wont start | GENO 300 | Enduro Engine - 2 stroke | 0 | 09-21-2009 10:02 PM |
wont start | clerky clerk | Enduro Engine - 2 stroke | 8 | 11-01-2008 01:18 PM |
