Old 09-07-2012, 12:16 PM
Banned
Default Ring Gap question.....again?
Just wanted to run this by the guys on here that know ALOT more then I do. My old rings in my EC250 measure at .6mm, the new rings going in measure at .4mm. Seems a little tight but still in spec. with what wiseco says. Wisecos minimum specs are at .1mm or .004 in.
I decided to replace the rings because my compression was down to 130 psi.
O.k. a rant! DANG IT!!! It's pissing down rain now and I have the jug off of one bike and a flat on the other.......argggggh! Sorry, It just never rains here!
Old 09-07-2012, 03:38 PM
0.4mm is good. 0.5mm is safe. I put my rings in at the minimum end of the scope when I did mine. Around 0.3mm. The wiseco calc works (Wiseco's site provides a formula : bore * multiplier. The multiplier is a function of the application.)
Old 09-07-2012, 07:36 PM
Banned
Thanks Jakobi, I knew I could count on you!
Cylinder head o-ring question Cruiser Enduro Engine - 2 stroke 4 04-14-2011 08:58 AM
Dyna Ring Question jdosher General Discussions & Announcements 0 03-30-2011 06:24 PM
Ring Question PEB Enduro Engine - 2 stroke 4 02-14-2008 01:10 PM
Head-gasket O-Ring question FFRDave Enduro Engine - 2 stroke 5 01-12-2008 09:56 AM
Ring gap brains Enduro Engine - 2 stroke 1 07-10-2007 06:09 PM
