Old 06-24-2015, 07:43 AM
pscook's Avatar
pscook pscook is offline
Originally Posted by pigpen966 View Post
The shaft is actually about 1mm shorter overall but the distance from the top of the drive gear to the keeper on the bottom is longer.
So you just need to relieve the top housing for the thicker gear? That sounds like the perfect fix. How did you order it? Do they have an online store, or did you have to call them?
Phil
(New bike pending...)
Old 06-24-2015, 05:54 PM
pigpen966 pigpen966 is offline
Yep, about 10 minutes with the dremel.
http://www.dbelectrical.com/
These guys a great. The nice thing is now if the bendix fails it is a simple change out for $22. I'm going to order a couple more to have in stock.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 06-25-2015, 06:24 AM
dANbOT's Avatar
dANbOT dANbOT is offline
I should be getting my bendix within a week, got my Dremel kit ready for the mod!
Thanks for figuring this one out pigpen! I'll report back with my results
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 06-26-2015, 04:14 PM
Wimpy525 Wimpy525 is offline
Ordered mine on Tuesday and got it today. DB wanted 49.00 but found it at OMB Warehouse for 25.00. I may machine the gear down verses grinding the housing down.
Old 06-30-2015, 05:49 PM
Ended up pressing my old top gear off and installing on the new bendix. Starter works great now.
Old 07-01-2015, 10:26 AM
Neil E. Neil E. is offline
Interesting that the gear on the left has a small detent to match the pin on the housing. Which way is the photo? Stock unit on the left, new unit with old gear on the right?
Old 07-01-2015, 03:25 PM
New unit is on the right. Both gears had the same detent, little tricky to get lined up.
Tried the e-start about a dozen times with no misses.
Old 07-03-2015, 06:36 PM
dANbOT's Avatar
Ok, I just finished installing my 5009 bendix.
I pretty much did the same mod as pigpen, took a little off the bottom end of the shaft, and clearanced 1mm or so out of the inside of the cover. Took me about 10 minutes with a dremel. It works like a charm!
Now that I have done the mod, the 5009's will pop right in if I ever have an issue with this one.
Thanks for doing the leg work on this one pigpen!
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 07-06-2015, 01:09 PM
Biff's Avatar
Biff Biff is offline
Well......
Midweek ride last Wednesday cut short due to bendix seeming to not disengage fully.
Due to over greasing.
So bendix out and cleaned. Quick blast round the block and not happy with "tinkling" noise.
Tonight took off side cover to find dirty grease full of swarf / filings.
Turns out centre locking nut on stator? Had come loose, could loosen by hand.
Ring gear has been rocking back and forth!
So....
Can I buy the 'outer' of the stator only, or the whole lot?.
Presume I need to also buy puller?
I also presume there is a key way on the shaft so straight off and replace
With no need for timing tweaks ?
Will post pics soon
Ta
Old 07-06-2015, 01:24 PM
Biff's Avatar
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Originally Posted by Biff View Post
Well......
So....
Will post pics soon
Ta
Just a hillclimb FAIL - Lesson 1 How to break rear fender blamir Pictures & Videos 3 04-06-2015 11:34 AM
First real fail........ houndog Injury & Recovery 27 06-16-2013 12:36 AM
Wiring Epic Fail (2011 EC200 Six Days) TEricksen Enduro Electrical & Wiring 0 02-02-2012 08:24 PM
wet clay + shot rear tyre = fail boundy Pictures & Videos 21 03-31-2010 03:32 PM
