Old 08-08-2020, 08:08 PM
Banditpowdercoat Banditpowdercoat is offline
Default Power valve spacers
I have a CNC mill at home and wondering on the power valve spacers. Do people still use/need? I have made for my 98. 250. Not many other gg owners here I. Western Canada but if there's a want, I can make.
Old 08-09-2020, 02:31 AM
You could make some for the other side too to get rid of that silly 5mm cardboard gasket.
Old 08-09-2020, 11:22 AM
5mm gasket? On the linkage side? My 98 is just a regular gasket on the linkage cover.
Have you a pic?
Old 08-09-2020, 06:39 PM
Neil E. Neil E. is offline
If you really want a challenge there may be owners of 2011-2014 estart models who would like a spacer that incorporates the starter motor mount. The spacer might have to project out beside the starter motor to achieve the required volume.
Old 08-09-2020, 07:34 PM
Have you a pic?
Same shape. The 2018 model they changed the linkage so the cover requires more clearance.
Old 08-10-2020, 01:59 AM
Nocams Nocams is offline
2015 > requires the thicker gasket to clear the ball joint actuated bellcrank.
I?ve been using 6mm Delrin for years as the spacer.
2011 TXT300R
2018 EC300GP
Old 08-11-2020, 08:42 AM
I took a educated guess at the thickness! Save me an off cut will you?
Old 08-13-2020, 09:26 AM
I?ll even make it for you matey!
How?s the carcass going? You healed yet?
2011 TXT300R
2018 EC300GP
Old 08-13-2020, 02:11 PM
Cheers bud! 🤘
Yep all good to go when I get some time off!
Old 08-15-2020, 05:36 AM
You two a good fellas! I'll have a beer for each of you after a good ride today!~
Power valve viper77765 Enduro Engine - 2 stroke 11 03-11-2019 09:56 AM
Ec 300 power valve Jonisaacson17 Enduro Engine - 2 stroke 11 07-18-2016 09:01 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
