Old 05-06-2018, 03:52 PM
sheepy sheepy is offline
Default ec 300 2012 jetting (needles)
ive just done a full engine rebuild and after a few rides thought it was running a bit lean it was overheating blowing out coolant and pinking. so i pulled out the carb as1 and found a 170 main jet, 40 pilot, n1ef needle on top clip, air screw 3 turns. so ive put it back to the standard 42 pilot, 175 main, n1ef #2 and air screw 2 3/4 turns. and i find that it is to rich from around 1/8 throttle all the way to wot. i understand 2 3/4 turns is to far out should be between 1 and 2 for best results so going to drop back down to 40 pilot. but for the top end was thinking of running a different needle either a n3ch or nedj do you think they will be suitable with the current jets? will be used in-between 50-2000ft
Jetting (needles) 2013 gasgas ec 250 nickp Enduro Intake/Carburetion - 2 stroke 7 11-03-2013 02:25 PM
2012 300 jetting bones150 Enduro Intake/Carburetion - 2 stroke 3 05-10-2012 05:56 AM
2012 300 JD jetting kit mblazer11 Enduro Intake/Carburetion - 2 stroke 11 04-17-2012 10:12 PM
Where to buy needles. Other jetting questions. IDAHOSPUD Enduro Intake/Carburetion - 2 stroke 1 11-07-2011 02:08 PM
JD Jetting Spreadsheet - anyone know codes for JD needles ?? DaveH Enduro Intake/Carburetion - 2 stroke 1 02-13-2011 09:40 AM
