Old 06-01-2014, 06:27 AM
Rzez Rzez is offline
Default Removal of break pads help 1998 ec250 brembo
Hi all!
Got myself an old ec250 1998 to see if I like green laning. But it needs a little work.
My main issue is I can't seem to get the metal rod out. None of the utube vids have the same type of rod. mine has a smaller whole closest to me with no screw to twist and the other side is almost like a nipple but it's inside the calliper so can't get to it.
Question is after taking the pin out do I just get a back of a nail to put into the small whole and hammer away until the pin pops out the other side? Or is their a better way of doing it? Really don't want to break it!
Thanks again
Mike
Old 06-01-2014, 05:30 PM
Rick's Avatar
Rick Rick is offline
Originally Posted by Rzez View Post
Hi all!
Thanks again
Mike
The rear Brembo pads are held in by a small pin that is secured in place by a clip style pin.
Once that pin is removed you can tap it out using a very small pinch. If i remember correctly there is a indent bearing on on end of the brake pad retaining pin. That small bearing may be rusted or your brake pin might have some serious grooves worn into it?
Might be easier to remove from the bike and work on it on a bench?
I'm sure your going to have to get creative to get it out if it has been neglected over the years.
Hope that helps.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 06-03-2014, 04:09 AM
savage sausage's Avatar
savage sausage savage sausage is offline
spray it with wd40 leave it for a while and tap it out with a small punch from the end with the smallest hole.
throw it away and buy 2 new ones.
http://www.racefxb2b.com/caliper-components/
make sure you copper slip everything to do with the brakes, if you have any damaged rubbers then buy some new ones, if not they will seize again & again.
brembo brake rubbers are expensive though about ?9 each when I bought them.
Old 07-21-2014, 05:39 PM
Thanks guys, got it sorted. You're both rite. Needed a punch, a hammer and some brute force. Thanks again for your help
Tags
break, break pads., brembo, calliper, ec 250
1998 Ec250 Yokes EC250 Enduro Suspension 11 10-24-2013 07:55 PM
Help needed on 1998 GasGas EC250 daw003 Enduro Suspension 2 04-02-2012 02:31 PM
1998 EC 250 Rear Brake Pads nick2510 General Discussions & Announcements 0 12-20-2010 11:27 AM
1998 Gas Gas ec250 pferreira1970 Enduro Electrical & Wiring 0 10-19-2008 11:41 AM
