Old 03-03-2008, 09:11 PM
Gregarious Gregarious is offline
Default 2 finger clutch lever
Does anyone know of a 2-finger after-market clutch lever? I'd like to keep my stock one un-altered as a replacement or in case I end up not liking a 2 finger lever.
When I last ordered some parts from GoFasters they mentioned ASB (if that's the right name) might be making some.
Old 03-04-2008, 12:20 AM
JRDoz JRDoz is offline
I have a shorty clutch lever I purchased from my local GasGas Dealer.
It's an original part you should readily be able to get....
"It's Nature that Brings out the Madness"
GasGas FSR450 07'
Old 03-12-2008, 01:17 AM
2t nick 2t nick is offline
Location: rye back beach (mornington peninsula),victoria australia
Smile
i run a longer lever and just slide the resivor up the bar about 2.5 inches
so you only use 1 or 2 fingers on the lever and its makes it a heap lighter too
Old 03-12-2008, 07:23 AM
eff's Avatar
eff eff is offline
Doesn't the lever hit the collar on the grip?
2004 GasGas DE250
Old 03-12-2008, 09:24 PM
that doesn work to well if you ride tight trees and have to cut the bars down and are running bark busters. I ordered a shorty lever from the local gasser trials dealer, it turned out to be the same length as the stock lever. Don't know if your going to find anything much shorter
Old 03-13-2008, 03:22 AM
gasser's Avatar
gasser gasser is offline
Smile
The trials levers come in 2 lengths and are available aftermarket. - Ken
Old 03-17-2008, 04:14 AM
No all you do is just cut a small semi-circle out of the the grip
Old 03-17-2008, 07:29 AM
eff's Avatar
eff eff is offline
Simplicity is bliss isn't it!
2004 GasGas DE250
Folding clutch lever sen480 General Discussions & Announcements 4 01-16-2010 10:02 AM
clutch lever to big rupecopp Enduro Chassis & Body 3 06-09-2008 05:15 AM
$ 30 for a clutch lever ? fasternat Enduro Chassis & Body 1 09-21-2007 12:01 AM
Clutch Lever Bushings PEB Enduro Chassis & Body 1 05-27-2007 03:02 PM
