Old 01-30-2013, 10:10 AM
Scar13 Scar13 is offline
Default Metal on metal sound when O-rings from exhaust wear out.
Hi Everyone,
I have fixed this 4 times in the past year.. The o-rings SLIGHTLY wear and I get a metal Buzz sound from the front pipe. If I put my boot on the pipe it stops of course and if I change the O-rings it stops...
So I know the problem and how to fix it, but it should not be happening every 4 -6th ride and Is there a known issue with this? I ask because Gofasters has a replacement exhaust spigot.. Seems ODD to have one on the site like that?
Old 01-30-2013, 11:12 AM
Banned
McMasters has better viton o-rings that hold up much longer. I can't remember the size, but GMP knows what size they are. Or you can do a search here on them. I would look it up but I'm on my phone and it will take to long.
Old 01-30-2013, 12:16 PM
Zman's Avatar
Zman Zman is offline
Another option is to clean everything really well and use high temp RTV to seal the connection.
Old 01-30-2013, 12:56 PM
Mattnzl Mattnzl is offline
This is what I'm trying next - worked great on my KDX.
Old 01-30-2013, 01:18 PM
Ps, I use the rtv sealent I have used red, and nine I'm trying the copper..
Old 01-30-2013, 02:36 PM
Check the alignment of the pipe, and also the lower pipe mount. I've found if the lower mount is flogged out it allows too much movement of the pipe which causes too much wear on the seal.
As above Viton o-rings and RTV Red. I was going through this every couple rides until I fixed the mounts up. Since then I can really scrag out the o-rings.
Old 01-30-2013, 05:27 PM
Mc_Grath Mc_Grath is offline
I have had this problem and I found that the left side of the pipe was pushed backwards so the pipe did not fit straight on the cylinder.
Old 01-30-2013, 08:52 PM
jostby jostby is offline
nail a stump just right and it should make the fit nice and tight to stop that buzzing
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 01-30-2013, 09:05 PM
(F5)'s Avatar
(F5) (F5) is offline
One pipe buzzed & one didn't. the pipe that didn't was twisted & the front mount was twisted to get the bolt in. More tension, but pain in arse to fit.
I ended up fitting some extra springs on the manifold. buzzing stopped on straight pipe. (+ viton & sealant)
Old 01-31-2013, 05:06 AM
actually what I did was push it forward with the spoons I use to change the tires. It got better, but when it became perfect is when I hammered it (putting a piece of timber between the pipe and the huge hammer. Now the bike sounds like new No kidding
High pitch Squealing from exhaust and exhaust flange????? Scar13 Enduro Engine - 2 stroke 5 02-11-2012 11:32 AM
Metal shavings in oil mikemoto General Discussions & Announcements 4 08-28-2011 10:51 PM
Large piece of metal from drain hole??? desertgasser300 Enduro Engine - 2 stroke 16 06-22-2011 08:12 PM
EC250 exhaust O rings? BIG TOOL Enduro Engine - 2 stroke 17 09-10-2010 04:31 AM
Mothers Metal Polish Boomhauer Enduro Product Reviews 3 06-23-2007 07:02 AM
