Old 01-17-2017, 06:29 AM
CanGasser's Avatar
CanGasser CanGasser is offline
Well I'm back to doing this swap, bought a set of 2008 SSS with the YZ triple clamps so I am going to just drop these in. What have everyone that did this find best, Use a YZ wheel and caliper or use the GASGAS one? I have a 2003 YZF parts bike I could use the stuff off or could use the GASGAS with a caliper bracket and different axle if I am correct. My guess would be to use the YZ wheel, I think I read somewhere the GASGAS caliper will bolt up the the YZ bracket.
thanks
Scott
Current: 2007 GASGAS 300EC 2004 KTM 250 SX 2003 YZ450F
Old 01-18-2017, 12:44 AM
i had some new spacer made by twowheels (steve Beane) that enabled me to use the GG wheel, bearings and seals with a yz axle (it sticks out about 15mm on the RHS)
for the brakes you will need an adapter to convert the yz caliper to a 260mm disk (made by braking http://www.motorcycle-superstore.com...mm-front-rotor)
And lastly i just had a GG top triple clamp machined out to match the yz forks
Old 01-18-2017, 04:27 AM
fullthrottle's Avatar
fullthrottle fullthrottle is offline
I just used everything from the yz and had a steering stop welded on
06 EC250
Old 01-18-2017, 06:50 AM
Elvis74 Elvis74 is offline
I changed mine now. I went back from the YZ tripple clamp to the original gasgas. I machined the clamping diameters to fit the KYB SSS
Gesendet von iPhone mit Tapatalk
Old 01-18-2017, 05:40 PM
CanGasser's Avatar
Can anyone confirm the head stem bearing sizes so I can get those ordered?
Thanks
Scott
Old 01-18-2017, 10:39 PM
All balls has a section on their website that has bearings sizes for conversions
Old 01-18-2017, 11:08 PM
In my thread. . , Erm hijacked thread
http://www.gasgasrider.org/forum/sho...ht=tech&page=4
Old 01-19-2017, 04:49 AM
_Hammy _Hammy is offline
Hi Scott, I see you're using SSS's off an 08 YZF which I think have a 32mm fork lug and thus changing the steering geometry (if you're keeping the GG triples).
I'm about to step into this conversion for my 09 ec300 so are interested in anyone's real world feedback on the geometry changes on the older chassis, and whether it is an issue of not
At this stage I'm keen on keeping my triples and boring them out and keeping my front wheel (running tublis)
Sorry for the hijack ;-)
Old 01-19-2017, 06:52 AM
CanGasser's Avatar
Hey F5 thanks, so the bearing are just the standard YZ bearings almost like the GASSER was meant to have the SSS forks.
Old 01-19-2017, 07:01 AM
CanGasser's Avatar
[QUOTE=_Hammy;174150]Hi Scott, I see you're using SSS's off an 08 YZF which I think have a 32mm fork lug and thus changing the steering geometry (if you're keeping the GG triples).
No Worries
I was going to use the GASGAS triples and wheel, but the forks came with the Yamaha triples and I just happen to have a YZ front wheel so I am going to go that direction. Seems to be the simplest. Just trying to confirm the caliper and bearings. That bike's getting alot of love I'm rebuilding the engine and installing new forks and installing tublis can't wait to ride her in the spring.
EC300 2007 Front wheel not centered in forks Paynebrody Enduro Chassis & Body 1 01-12-2016 07:37 AM
EC300 2007 New forks stian Enduro Suspension 10 06-05-2014 10:37 AM
WTB Forks 02 GasGas XC 300 Mike Leach Parts 3 04-08-2013 10:46 AM
