More aggressive bottom/mid needle recomendation?
Currently have a NEDW and feel it is just a bit too soft on the bottom and mid. It is just kind of lack luster in the power department. Nice on top end, but in the woods I rarely get up there to enjoy it.
Not looking for something that will rip my arms off, but some more bottom end grunt. |
Im walking the same path with nedh on a 200.jakobi mentioned nech which is half clip leaner.so if youre running ned# In clip2,then nec# in clip3 will be 1/2 clip richer.i havent tried it yet tho but will.im also curious to try a leaner slide with stock noz# but its $20 needle,$130nz for slide
2013 ec200r |
You have a couple of options when it comes to getting a new slide. http://www.rb-designs.com/rb_designs_llc_013.htm or http://jetsrus.com/carburetor/carb_k...iew_parts.html |
Here's my setup on my '13
N3CJ needle 2nd position summer, 3rd position winter 175 main (now 170) 40 Pilot 4500' and up for altitude. Head has been cut to tighten squish and the comp is pretty high. Like on the verge of needing race gas. But, at my altitude I have a pretty good safety net. At sea level it will ping a touch at idle after a hard run. Could probably be fixed with a little jetting. As for how it runs, I like it. Not really a hit. Very smooth. Lots of low end grunt. Like long rocky technical steep climbs in second, like when I think I need to downshift I just roll on the throttle and it just keeps going.
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
My set-up for Ohio
13 300 N3CJ clip 2 178 main 42 pilot This is perfect for my riding, I do a lot of trail work and single track. Very smooth, easy start, little spooge
Dick Carnes "If ya run, you'll only die tired" 2019 EC 300 2018 GP 300 2013 XC 300 (sold) 2006 DE 300 (buddy has it) |
The slide # is stamped on it.my 13 200 has a 6,nozh stock,but that doesnt mean a lot if you have a 14,300.the 13 manual lists a 7slide with n1ef for 200,250,300(usa)...go figure,the only way to be sure is to take a look i guess
2013 ec200r |
The n3.. range of KTM needles is probably what you want. I used to have one on my bike and it was definitely more "fun" than the NE.. that I have now, harder hitting in the mid but still good traction at the lower end
@swazi_matt,is big difference between nexx and n3xx in torque parameters ?
Wtb 03 250 bottom end | papagasgas | "Wanted to Buy" & "Want To Trade" | 0 | 08-30-2015 02:44 PM |
Keihin PWK needle jet size? (not the needle it self) | David v | Enduro Intake/Carburetion - 2 stroke | 3 | 12-05-2014 08:16 AM |
'05 125 bottom end | marshalls113 | Parts | 0 | 04-14-2014 08:16 PM |
wanted ec 250 bottom end | dinger | United Kingdom | 2 | 07-19-2012 03:43 PM |
