2011 250ec/300 cylinder swap
Hey guy, i have a 2011 ec 250, i would like a little ore bottom end out of it,i was thinking of putting a 300 jug on it.
Here are my questions 1 will the 250 head work with the 300 cyl. 2 is there a better(cheaper) way of getting bottom end torque out of this bike , i just pit a piston and rings in it last year. i guess what iam looking for is a little more bottom end , my dad rides this bike now and he rides a little slower but still wants some bottom end grunt !!! thanks in advance guys |
Welcome to the forums.
1)The 250 head won't work on the 300. 2) There are several options. a) Install a flywheel weight. b) Install a high volume power valve cover-on left side of cylinder. Non e-start only. c) Adjust the power valve actuator to open the valves later. You will have to pull the clutch side cover off to do this. |
This is great thanks gasgasman, i will try the power valve adjustment , i have a estart so for the rest iam up shit creek without a paddle . i was really hoping that head would work lol. thanks again. |
You're welcome.
For massive low end power, you'll have to get a 1998 Gas Gas. The motor has a counter balancer and a heavy magnetic type lighting coil. |
is the lowend alot different on the 300 compared to the 250 or should just gear it for the old guy lol
You could get the head set up properly, they are notoriously poor from factory.
Jet it a bit fat. Bigger rear sprocket, 52T. An FMF gnarly pipe. |
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
2011 rear master cylinder brake rebuild | BrentMartell | Enduro Chassis & Body | 3 | 06-09-2014 09:52 AM |
2011 250EC sixdays | knobbyboy | Used Bikes | 0 | 03-12-2014 10:55 AM |
