2006 Pampera 400 - Ignition Fault (No Spark) - call for help
Greetings from Australia GasGas lovers!
I'm looking for any and all info anyone has on the '06 Pampera 400 (or models that used the same ignition system), I believe the '05 FSE 450 was the same or similar. PROBLEM: I've got a no spark condition, new spark plug, and a new ignition coil hasn't helped. I'm measuring ~3VAC coming out of the pickup coil (and ~20 ohms) but no more than a few mV out of the CDI into the ignition coil, obviously not enough to make a spark. The suspect is currently the CDI but I cannot find a spare part - my next step is to give this a whirl: https://www.jaycar.com.au/capacitor-...bikes/p/KC5466 However this is a 5 wire CDI, while the Kokusan Denki CDI (CU7471) has 7 wires. I'm guessing at least 1 of the 2 additional wires is for RPM on the digitial display but am yet to confirm this. If you've got any of the following I'd love to see it; - wiring diagram - CDI wire colours - spare part reseller for CDI (Kokusan Denki CU7471) - is there another model that uses this CDI? - is there another CDI that the Pampera 400 will run on? I've noticed a few similar era Huski's have the same physical shape CDI but with different model numbers, so no idea if they'll work Thank you to anyone who reads this and keep on Gasgassin' |
Tags |
cdi, electric start, electrical, ignition, wiring |
No spark ec300 2006 | Sjoblom! | Enduro Electrical & Wiring | 30 | 05-21-2021 08:12 AM |
Bad bottom end possible electrical fault | Mostin3 | Enduro Electrical & Wiring | 6 | 01-01-2018 11:03 AM |
2006 EC200 ignition fault diagnosis | Caravan Monster | Enduro Electrical & Wiring | 13 | 04-26-2016 03:17 PM |
A lot of fault spark plugs... | dimtsam | Enduro Intake/Carburetion - 2 stroke | 6 | 11-14-2014 09:51 AM |
Fuel tap fault | Warwick Simpson | Enduro Intake/Carburetion - 2 stroke | 0 | 11-09-2008 12:15 AM |
