Sachs bleeders ec 300 2008 ?
Is possible to find this breeders? Dimension of screw part seams to be so small then others.
Who can tell size of the thread and the other? EC300 2011 |
I took my fork caps to an engineering shop and got them to enlarge and tap the holes to kyb specs
Does it means that you can't find bleeders for suchs?
i suspect it will be difficult since the sachs bleed screw is very small so not much space to put a hole through the screw to make bleeders.
it seems they may have changed the forks for 2011, as the description for these mentions that it also fits kyb and showa (which had larger bleed screws than my 2010 sachs)
http://www.motocrosscenter.com/shop/...aign=Doofinder
Looks like here they are
https://ru.aliexpress.com/item/Suspe...6-42d0d852d118 And anyway, i guess it's not big deal to drill bigger hole in cap. |
Sachs fork bleeders for 2011 EC 300 | r00zter | Enduro Suspension | 7 | 04-30-2012 10:06 AM |
Sachs fork bleeders | Kiriakos cy | Enduro Suspension | 9 | 01-18-2012 08:08 PM |
Sachs Fork Bleeders? | mrkartoom | Enduro Suspension | 11 | 04-25-2011 09:10 PM |
Speed bleeders | splint | General Discussions & Announcements | 7 | 09-08-2009 12:20 PM |
Fork Bleeders | cladoo | Enduro Suspension | 6 | 01-18-2007 02:27 PM |
