Go Back   Rieju & GasGas Legacy Riders Club Forum > Community Forums > Australia & New Zealand
Old 10-25-2006, 06:28 PM
west aussie gas 450's Avatar
west aussie gas 450 west aussie gas 450 is offline
Unhappy Engine mounts on to frame
: Have just brought new 450fse and have developed cracks in welds where the front engine mounts bolt on to frame ?Oil is seeping through from oil well wilst motor is runing?My dealer says bring it in[bike] an he will put some plastic metal on it, sounds a bit dodgy to me has anyone else had any probs with this engine mount?
Old 10-25-2006, 09:29 PM
guy you should move this to the general section so more eyeballs will see it. I'm not sure but it sounds like your frame developed cracks at the engine mount welds big enough to let oil in the frame sump to seep out. If this is correct I would settle for nothing less than a brand new frame and imo I think a whole new bike is in order. Those bikes go for about $7000 USD in my nieghborhood. thats too much money for bad frame welds. thats a manufacturing defect. If it was caused be a bad weld ... how many other welds are on that frame?? Get a new bike or new frame. Nothing less!! The fact that the dealer is suggesting plastic metal would scare the hell out of me!! If dealer gives you a hard time go to the gas gas rep. No luck there go to the importer. no luck there call spain.
Old 01-25-2007, 05:03 AM
Sandman Sandman is offline
If you have a 2006 FSE you will find that it is not a crack in the frame but a small pin hole in the weld and the oil is from the breather going into the frame
and leaking, It not a big deal I just put a bit of steel cement on the pin hole and painted it black. and now I have 9500km and no problems.
If it is a pre 2006 model it is the dry sump type and the frame is used for an oil tank, but not on the 2006-2007 models.
Old 01-28-2007, 08:16 PM
Thumbs up oil leak in frame
Tanks Sandman, I've put plastic cement on the crack an it only weeps now an then after start up no dramas.
2002 frame; same as a 2005 frame, or close enough? Trooper Sam Enduro Chassis & Body 0 06-10-2010 09:18 AM
Taller Bar Mounts Boomhauer Enduro Chassis & Body 6 11-09-2008 07:49 AM
An 01 GG 300 engine in an 04 GG 200 or 300 frame? prentice Enduro Engine - 2 stroke 5 02-07-2008 12:07 PM
Which mounts better - GPR or Scotts Roy Salmon Enduro Chassis & Body 3 01-25-2007 07:45 PM
engine mounts on to frame west aussie gas 450 Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-26-2006 08:59 AM
