Old 03-02-2021, 01:35 PM
5valve 5valve is offline
Default '18 GP 300 Linkage - wtf
Prepping bike for season, first time linkage checkup.
Linkage movement hard, opened, nothing problematic, cleaned, regreased.
Tested in vice, to check free movement - hard AF. Both connections.
Linkage links are moving fine.
What I realized is, that the large washer, being 0.9mm is too thick and it grinds into spacer.
Bushings should be just a fraction longer.
If remove only one of the two washers, spacer falls in too much, but free movement is obtained, if held in hand. If it were bolted with washer removed, it would be alu-alu grinding.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 03-03-2021, 09:17 AM
Looks like you're overthinking it.
Once the bolts are tightened, there's no movement between the spacer and the bushing.
Old 03-03-2021, 09:27 AM
You dont understand.
Once tightened, and this is tested, it hardly moves, but should flow freely.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 03-06-2021, 08:29 AM
Remove seal, remove one 0.9mm shim, reinstall seal. Spacers now sit closer together, but finally they rest on the bushing, which moves inside bearing.
Reinstalled, perfect fit, torqued, no free play, all the free movement regained.
EC 300 2008
EC 300 2018 GP
tenere 700
Scorpion linkage to trade for stock linkage rvangeel "Wanted to Buy" & "Want To Trade" 0 06-13-2019 08:25 PM
11 linkage kit on a 13 andykr87 Enduro Chassis & Body 2 01-14-2018 06:12 PM
Linkage help please! liv2day Enduro Chassis & Body 8 10-20-2017 12:06 PM
Linkage redrider7202 General Discussions & Announcements 12 05-18-2010 09:05 PM
Linkage redrider7202 Enduro Suspension 1 05-12-2010 05:34 AM
