Old 12-22-2015, 01:46 PM
AZRickD AZRickD is offline
Default 125+ Hours. Time for a top end job
In the middle of Arizona's race season and multiple Holiday's off, I decided it was time freshen up this 2011 EC250R. A Vertex piston from MotoCity.
This is my 3rd effort on a GG top-end (three on my 2005 EC250 back in 2011).
Any advice is appreciated.
Old 12-22-2015, 03:33 PM
Sticking with the A-cylinder.
The motor came out of the factory with a .5mm base gasket. I think I'll go with the .3mm.
With my RB head mod, the squish band measures at about 1.35mm as it sat with the .5 base gasket. I originally had it set at about 1.05mm with a .3mm.
The power valve looks too good for me to mess with it. Leaving it as is.
I am hoping that I don't install the PV linkage backward, somehow. Is that possible?
Old 12-22-2015, 05:43 PM
Piston pics.
Old 12-22-2015, 07:34 PM
Doing heat cycles.
Old 12-23-2015, 12:17 AM
What jetting had you been running?
Old 12-23-2015, 10:00 AM
liv2day's Avatar
liv2day liv2day is offline
Hey Rick -
It sounds like you already have everything together, but for future reference, this was a huge help to me when I did the top end on my 200 for the very first time: http://www.gasgasrider.org/pv_disassembly_mattr.pdf
These two YT videos were instrumental as well; show the PV assembly on a GG300.
https://www.youtube.com/watch?v=hmz9cij6MVY
https://www.youtube.com/watch?v=FQJs2qM3rT8
Hope she runs like a beast and that new piston gives her lots of pull
Old 12-23-2015, 10:10 AM
Liv2Day, Thanks for the links.
Jakobi, I'm running a Lectron. I tend to run things fairly rich. Most riding in Phoenix is between 1K and 3K feet. I don't change anything when I go to Flagstaff (7K to 9K).
Bottom of the piston is barely discolored. Two small amber areas.
Time to do one more heat cycle this morning then I'll let her rip.
Old 12-23-2015, 02:40 PM
How's the heat and mixture ?
Old 12-23-2015, 02:42 PM
Piston top --
Old 12-24-2015, 12:42 AM
GGRider01 GGRider01 is offline
At least you can read the writing on the top of yours. I got my bike with the original piston in it.. 15 years after it came to the US. There was at least a 1/16th of an inch of carbon caked on the top. It had no carbon below the rings, interestingly. Washed perfectly clean and shiny like a mirror.. It was definitely overdue.
FMF Q-Stealth 2T with 75 hours AZRickD Enduro Engine - 2 stroke 7 04-08-2014 12:56 AM
400 + Hours First Top End Ec250 gasgasquebec General Discussions & Announcements 6 08-11-2011 10:00 PM
24 Hours of Maplesville Rod Overstreet Off Road Racer's Corner 0 05-01-2010 04:16 AM
