Old 07-27-2009, 01:00 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default GG specify piston/bore clearance 0.06mm where is this measured?
Is it minimum jug diameter (narrowest point) to quoted piston size (not sure if quoted piston size is the max diameter?) in effect meaning this would be a minimum clearance cold.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Where is a piston measured 71.95 at top, middle or bottom? stay_upright Enduro Engine - 2 stroke 1 07-25-2009 07:34 PM
Measured Squish @ 1.83mm! GG27 Enduro Engine - 2 stroke 9 06-11-2009 04:55 AM
FYI, check BDC piston/lower port clearance. socalscott Enduro Engine - 2 stroke 3 11-26-2008 01:43 PM
"B" piston in an "A" bore? Kokanee Enduro Engine - 2 stroke 6 09-04-2006 07:10 PM
