Rear wheel and Sprocket interchange?
Hi guys, can anyone tell me
1 - what wheels fit the ec300 (2006) 2 - what other bikes share the same size rear sprocket? 3 - will a 14 tooth front sprocket fit? Thanks!!! |
The rear sprockets are the same as Husqvarna sprockets. The front is GasGas only. The wheels are gasgas only as far as I know. Not too hard to find some part out wheels usually. The older u rims are the best in my opinion. There is aftermarket wheels available too.
2018 EC 300 |
My friend has a KX rear wheel on his 01 300 gasser so it fit with probably only spacer modifications. Rims are not interchangeable because GG USES A DIFFERENT LACING PATTERN than any major factory uses so the holes in the rim are drilled at different angles than you find on rims made for "the big five".
As for rear sprockets the 91-93 Suzuki 250 (and 350 I think) DR"S" is the same but the non "S" is not. For example the 91 250 DR"S" fits but the 91 250 DR does not. That kind of crap is why I don't own a Jap bike anymore. |
I have a late 90's KX250 wheel and a late 90's KDX200 wheel that both are almost a direct bolt on (rotor too!) to my '01 EC300. The brake side wheel spacer from the Kawi's is too narrow, but a couple big washers from the hardware store solved that.
I use a wheel from a 95 KX250(KX spacers as well), on my 01 XC250. Also used a couple big washers.
All healed up, and ready to burn some fat. |
Thread Tools | |
Display Modes | |
Help! Wheel interchange info '05 DE300 | DBR0051 | General Discussions & Announcements | 1 | 06-27-2009 10:02 AM |
Rear sprocket | steve | Enduro Chassis & Body | 7 | 01-22-2009 07:38 AM |
SM ing With MY 36t Rear Sprocket. | cal_tony | Enduro Chassis & Body | 1 | 12-30-2008 11:39 AM |
