broken clutch??
Hi all
was out for a ride yesterday when my not very old or worn front sprocket decided that it would strip half its teeth. One of the remaining teeth then instead of going in the gap between the rollers went through one of the rollers, resulting in the chain jammed up against my LTR case saver which locked up the back wheel and stopped the bike immediately. As the bike stopped I heard something crack, presently the clutch lever will not pull in at all and is locked solid, and the bike will kick over like its in neutral, however it is in about 3rd or 4th gear. I will clean the bike up next weekend and start pulling it apart to have a look at what damage has been done. what could have broken in the clutch or gearbox that would lock the clutch lever up and let the bike turn over while still in gear?? |
Probably the slave cylinder is damaged and the piston is jamed, causing the locked lever..
Steve |
Maybe damaged in a way that put pressure on the actuator rod, causing the clutch to be disengaged. Just hope the cases did not crack.
broken clutch plates? | stainlesscycle | Enduro Engine - 2 stroke | 24 | 09-27-2011 04:39 AM |
Broken Radius | noobi | Injury & Recovery | 23 | 08-28-2010 02:11 PM |
Broken Clavical | GMP | Injury & Recovery | 68 | 06-17-2009 07:09 AM |
Broken Link | Dingo | Enduro Engine - 2 stroke | 3 | 07-07-2007 07:15 PM |
Anyone else ever broken an air screw? | lukachuki | Enduro Intake/Carburetion - 2 stroke | 16 | 03-12-2007 07:43 AM |
