Old 05-11-2019, 06:10 PM
Davehuge's Avatar
Davehuge Davehuge is offline
These tables will help you with the Suzuki needles...
Be aware, the only difference between the NEC* and NED* needles is that the NEC* needle is half a clip position leaner than the NED*, or vice versa.
Old 05-11-2019, 06:29 PM
andrewjtheis andrewjtheis is offline
Thanks Dave! Now where can I find these bad boys? Did a quick search through my normal channels.
Old 05-11-2019, 07:14 PM
(F5)'s Avatar
(F5) (F5) is offline
First time through the gears 2 strokes often run a little soggy. This can be traced down to fuel not atomising as well some people figure, but I think it is more to do with the old floatbowl full of gas in a small vented area loses its light end gasses quickly.
I try to run out the fuel by turning the tap off on the way back to the carpark at the end of the day, and mixing in some new gas the morning of the next ride before opening the tap.
None of this is much issue if you ride every week.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 05-12-2019, 02:55 AM
Davehuge's Avatar
Where in the world are you?
I would try a Keihin dealer or Suzuki spares dealer. You can also try eBay but keep an eye out for cheap/fake parts from China, although normally these seem to be pilot jets and main jets, not needles.
If you're in the UK or Europe and need any Keihin jets or carb parts I can recommend this guy based in Holland...I'm pretty sure he ships worldwide too.
https://www.frankmxparts.com/
He also has a shop on eBay...
https://www.ebay.co.uk/str/frankmxparts
I've used him quite a lot, very helpful and great service.
Old 05-12-2019, 04:50 PM
Davehuge's Avatar
Tags
carb, jetting, spooge
Thread Tools
Display Modes
2010 gasgas 250ec evanchochrek Used Bikes 0 10-02-2015 01:44 PM
Power issues Langadave Enduro Engine - 2 stroke 1 10-24-2014 09:56 PM
aftermarket parts questions-2010 gg 250ec evanchochrek General Discussions & Announcements 8 10-21-2014 10:29 AM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
2010 EC300 Speedo Power Bradz Enduro Electrical & Wiring 0 11-19-2010 04:43 PM
