Used Bikes Used Bikes For Sale - No Part Outs |
SOLD '05 FSE450 parts bike/rebuildable
What I have here is an '05 FSE450 with ~6500mi that ran great until the exhaust cam decided to eat away a bit of the head where the journals sit. I don't have the time or $ for repair, and I'd rather not part it all out.
This bike was used pretty hard and has a few flaws, but was in good working order up to now. The bad...well, it needs a head (or repair to this one). The headlight shroud and right side panel are cracked. Dash is gone, replaced with a bracket to hold ignition switch. Rear inner fender got chewed up a bit from ice tires. Couple other minor things. The good...fresh rebuild on the clutch master, new rear brake pads, new batt as of a few days ago. Lots of serviceable parts...wheels, suspenders, frame, almost all of the engine, etc. Also have a box of parts including a fresh larger rear sprocket, a filter or two, a couple manuals, etc. Oh, and I have three tanks for it, which I may be talked into including...stock, a black Clarke, and a transparent Clarke that has a small crack where the pump mounts. I'm looking to get $900 out of it as is. Last edited by foxfire; 09-10-2015 at 11:25 PM. |
I should note, bike is located in central WI.
Bike is in storage awaiting repair, but I'm hard up for cash so figured I'd give this a bump. I'd take a reasonable offer.
$750? Anyone? I'd imagine wheels and suspenders would be worth more than that. Or sink a bit of $ into it and have a running bike on the cheap...
If you would be in Europe i would be interested in the engine...at least whats left of it. I just busted my crackshaft,cylinder and piston and kickstarter shaft holes in the casing are oval...
Where in wi? And is it still available?
Sent from my Nexus 4 using Tapatalk |
Bike is in Oshkosh, and still available.
Do you have any pictures of the damage?
Parts I'll never use 2002-3 FSE450 | Maddog | Parts | 2 | 06-02-2016 05:27 PM |
WTB 1999 gas gas ec 200 parts bike | sweeper | "Wanted to Buy" & "Want To Trade" | 0 | 02-26-2014 06:59 PM |
Trials bike and enduro parts? | lankydoug | General Discussions & Announcements | 19 | 03-16-2012 03:39 PM |
